I've got a Recaro Profi XL which looks very similar to this. Install is scheduled soon.
I've got a Recaro Profi XL which looks very similar to this. Install is scheduled soon.Thanks to MotorDrive's Allan & Melanie, I finally got their Cayman racing seat plus the sliding rail. I'll try to install it tomorrow if it's not raining, but the construction is top rate, service was excellent, and totally worth the wait.
For those who are a bit more, shall we say plump, this seat certainly fits the bill well. I'm 6', 215lbs with a 38" waist on a good day, and I fit snugly (exactly what I was looking for) without discomfort. I'll have to see how I actually feel once the seat is in, and how it feels on long trips (3~4 hours), but this may be the most economical (and I believe meets FIA specs) alternative to Porsche GT3 seats.
The seat itself weighs 17 lbs exactly, the sliding adjustable rails weights 17.2 lbs, for a total of 34.2 lbs.Can you weigh the seats before you install them and post the weigh.:thanks:
Just called Suncoast, Ryan was AWESOME - ordered the driver's side latch assembly with the connector (hopefully it'll connect correctly and the seatbelt warning won't go on).Good decision. I wouldn't want to cut any of the wiring either.
You undo the bolt at the bottom (17mm?) end and snake it thru the seat, then reattach. Look around for the seatbelt replacement article.... Haven't done it on the CS yet but I've done it to countless 911s and a boxster. Easy job.BTW does anyone know how you can "thread" the seatbelt through like K-Man did?
Very simple. just trace the belt to the lower attachment point. There should be a black plastic cap. It simply pops off with your fingernails or a flathead screwdriver. The bolt that the belt attaches to will be exposed. Simply unscrew that bolt. re-thread the seatbelt. Then secure the bolt again and put the black plastic cap back on.BTW does anyone know how you can "thread" the seatbelt through like K-Man did?
There's no chiming with the airbag warning light - you will get a message on the info center which you can clear with the left control stalk, but the little red airbag icon light stays lit. There's no problem driving with it on.The seat latch assembly arrived today so I'll be installing the latch on the seat when I go home. However, does anyone know if the car would do anything weird (like chime all the time) with the airbag warning light on? Also, should I wait and ask someone's help in using the PIWIS to disable the driver's seat airbag code beforehand or is it OK to drive with the warning light until someone can clear it?
Thanks!
