No way the stock one IMO. And probably not even PSE (which I have), but maybe that is. And if it is, it'd be a low-quality SS at that (not all are created equal), since it still seems to rust a little. Most factory exhaust systems are made of 'aluminized steel'. At any rate, unless Inconel (which I'm positive is not on our cars), I believe you can weld them the same way, but lets wait for a welding expert to chime in, since it requires the right welder, especially if you're welding the muffler (very thin sheetmetal). Finally, all exhaust systems usually have a little hole (or holes) for condensation draining. Just to make sure it's not something intended for that purpose, I'd post a picture of your 'leak', and a few of us could quickly tell you if our cars have it or not, and then you'll have the answer of what you need to do (if at all).
