I monitor temps in my 2008 2.7 Cayman with the Torque app and generally it runs around 183 to 186 range for most driving. The thermostat and water pump were replaced with the coolant caps and a third radiator added within the last 10k miles. Occasionally, and now much more frequently when sitting in traffic it will start to get too hot. Up into the high 190 too hot. When I checked the coolant level it was down a few ounces but not anything significant, the pump shows no visible leaks, grinding or end play. So here is the interesting part with my Durametric I can activate the radiator fans but they will only spool up for a few seconds and then shut down. Does this indicate an issue with the fan control module? Is there anyway to trouble shoot these? I can run the engine compartment fan and smog pump through the Durametric until I turn it off. Anyone have experience to share?
The other weird thing is my parking lights do the same thing?!?
