1 - 15 of 15 Posts
After following this forum closely since 2006, I just recently purchased my fist Porsche, a 2012 Cayman R with 18,000 miles from a non Porsche dealer. The car is absolutely amazing! The dealer said they changed the oil before the sale. My question is since the car will mainly be used as a weekend toy, should I have the 20,000 mile service performed now, or can I just wait for the next service in 12 months?
Appreciate any feedback.
If it were mine, I'd have the oil changed. Wouldn't want old oil sitting in my new toy for another 12 months.
Machog
The 20,000 mile service is not too involved and may be worth considering. At a minimum, might be worth having the brake system flushed based on age if that has not been done as well as a 4 wheel alignment if that has never been done, either. Just a thought...............
Are you certain that the 20 K maintenance wasn't already done? It should have been done in 2 years or 2014. Almost every dealer will do an oil change before selling a car, so I wouldn't worry about that. The brake fluid should be changed in 2 years.
Discussion Starter #7
Here are some pictures are recently took.
Thanks again for all the great info on this forum.
First that is a BEAUTIFUL R... Classic combination!! Noted was to have an alignment done. I assume the R and the Spyder have the same spec for alignment. Is the alignment different than a Boxster / Cayman in standard trim? I ask because as with Madrax my spyder is a weekend toy as well. Should the car be set to a different spec to enjoy it based on such use?
Did not mean to hijack the the thread but thank you.
That is a nice car, must be a beast to drive. Fairly certain the R sits a little lower so that may impact the alignment. Check your tires for the proper pressure and for any abnormal wear.
Congrats on the purchase. Incredibly jealous of that interior. Did you have a PPI done prior to purchase? Also if you provide a Porsche service advisor with your VIN they might be able to check in the system to see what all has been done (assuming it was at a dealer).
1 - 15 of 15 Posts
