The nav map shows up in the window on right of tach at odd times. How do I keep it from coming back when not in use ?
Yes you can. RTFMI don't think the 1st action can be turned off.
If you send a way to remove it from the menu, it would help. [email protected] Thanks to all for the replies.Yes you can. RTFM. You can add or substract whatever you want from that menu, so you don't have to scroll thru so many pages if you don't want to (and that's with any steering wheel). The only possible exception might be the gauges, but all other pages can be added or removed from the menu. I removed the radio, since I always have the radio on the main screen. But left all others. Navi only comes up when active, and a turn is coming up or something; quite useful IMO. But primarily use the gauges, and the G meter and TPMS every once in a while. Might remove a couple of other pages I never use, for quicker scrolling.
There's a graph with all the multi-function menus on page 84 of my 2016 CGTS, but as I said before, the manual on this car is the worst of all dozens of cars I've owned. The graph shows the menus you need, but doesn't go beyond them. So here is how to get to them, but you'll have to play with them since there're 2 that have nav functions. Since I have it activated on both, haven't had the need to play with them. Here is how, for the benefit of the membershipIf you send a way to remove it from the menu, it would help.
I may have disabled it today by going thru the choices w/the small wheel on the right of the steering wheel. I found & chose stop nav assist which has kept it from appearing so far. I'll try to remove the radio screen next since I seldom listen to it unless the road is smooth (quiet) & just cruising along between twisties.There's a graph with all the multi-function menus on page 84 of my 2016 CGTS, but as I said before, the manual on this car is the worst of all dozens of cars I've owned. The graph shows the menus you need, but doesn't go beyond them. So here is how to get to them, but you'll have to play with them since there're 2 that have nav functions. Since I have it activated on both, haven't had the need to play with them. Here is how, for the benefit of the membership:
With the gauges showing, push forward the stalk to bring up the menu. Select 'settings' and push forward again. Select 'display' and push forward again. Then you have 2 menus to play with: 'menu scope', where you can just unclick the squares related to nav (2, I think), and surely would stop any nav input... but you could also remove the very useful 'speed limit' from the dash. Play with it and find out. If it does, then you have the 'PCM display' menu where you could just unclick all nav options but leave 'speed limit', and it should work. Don't know why there're nav functions in 2 different menus. German complication, I guess. Ha ha. Hope this helps, and let the gang know what you found out after playing with it, for more precise instructions.
