2005 Boxster S only suspension mod is PSS9's.
approx. 1.5" drop F/R
Also running H&R spaces 15mm (F) and 18mm (R)
Looking for some feedback per attached alignment.
A few things just based on my research in this forum:
- Front/rear camber difference is at 1.5, it looks like the safe/recommended number is to be approx at a 0.5 difference for front vs rear. Will an additional 1.0 degree really make such a difference in understeer, unless on a really aggressive track run?
- Shouldn't left/right camber be similar, what is the effect with this setup?
I'm no expert on alignments but it looks like the main focus on this setup was toe settings to keep unever tire wear at minimal.
Any input would be much appreciated.
Thanks!
Thanks!
