After some poor brake performance at the track a few weeks ago, I decided to upgrade the brake pads and the fluid. Have changed pads on a previous car with no dramas and read through the articles section on changing fluid and pads, it looked easy enough so i thought I would do it myself.
Pad change was no problem and the fliud replacement seemed to go ok, except now my brakes have no pressure at all. I drove the car in my car park, it hardly stopped and there was a grinding feeling coming through the pedal when i really pushed hard, basically when the pedal was on the floor.
I bleed both nipples on each caliper, in the correct order, then did it again, it made no difference. I cant seem to work out what is wrong. Would really appreciate some advice.
On Probation
can you get a high pedal when you pump it up ? will it stay high or does it sink ?
On Probation
will the pedal hold psi or does it sink ? go back over your work and make sure the pads are correct then rebleed with a power bleeder
Thanks for your help.
I rang my independent porsche mechanic, said he'd come around after work and check it out for me.
I showed him what i did and he basically said the "one man brake bleed kit" i bought to pierce the nipple was letting in air and that i was better off using a plastic tube to cover the nipple completely. We bleed them again and problem solved. Brakes working fine.
But get this, when he finished I thanked him greatly for coming after work (this was about 8 at night) and told him to send me the invoice and he said dont worry about it, all part of the service. I couldn't convince him otherwise.
That's what i call great service.
I'll give him a plug even though there are only a few aussies on this site, if you're in Victoria, NINE PLUS are well recommended.
