1 - 20 of 43 Posts
Even More Efficient, More Sporting and for the First Time with Hybrid Drive
Stuttgart. Dr. Ing. h.c. F. Porsche AG, Stuttgart, is presenting the brand-new generation of the Cayenne Sports Utility at the Geneva Motor Show in early March.
The absolute highlight of this new generation is the world debut of the Cayenne S Hybrid with its technically highly sophisticated parallel full hybrid drive and fuel consumption in the New European Driving Cycle of just 8.2 litres/100 kilometres (equal to 34.4 mpg imp), which means
CO2 emissions of just 193 g/km. The Cayenne S Hybrid therefore combines the performance of an eight-cylinder with the economy of a six-cylinder running on much less fuel.
.Led by the Cayenne S Hybrid, all models in the new generation are trendsetters in efficiency and performance in their respective segments. Compared with the former models, fuel consumption is down by up to
23 per cent, since the new Cayenne, like every Porsche, has been developed according to the principle of “Porsche Intelligent Performance”: more power on less fuel, greater efficiency and lower
CO2 emissions.
These objectives result, not least, from the introduction of the new Tiptronic S eightspeed automatic transmission with Auto Start Stop and a wide spread of gear ratios, thermal management on the engine and transmission cooling circuit, on-board network recuperation, variable engine cut-off and intelligent lightweight construction.
Thanks to its special combination of materials for optimum weight as well as changes in the overall concept of the vehicle such as the Cayenne’s new active and extra-light all-wheel drive, weight is down for example on the Cayenne S by 180 kilos or 400 lb – despite the improvement of product substance and an even higher standard of safety. This clearly has very positive effects not just on fuel consumption and CO2 emissions, but also on performance, agility and handling.
.Benefiting from these features and new technologies, the new Cayenne offers even more driving pleasure both onroad and offroad, combined with even greater everyday driving qualities, enhanced comfort and supreme elegance. The completely new, sporting and elegant design of the new model integrates the 2010 Cayenne even more closely into the overall range of Porsche cars. The sports car-like character of the Cayenne comes out even more from all angles, just as the highlights in the shape and design of the car so typical of Porsche are also clearer than ever before.
Extra space inside and greater variability is ensured by the wheelbase now 40 mm or almost 1.6” longer. In all, the new Cayenne is 48 mm or 1.9” longer than its predecessor. But despite its larger exterior dimensions, the new generation of the Cayenne is nevertheless far more compact and dynamic. The most significant eye-catcher within the brand-new, high-quality interior is the centre console rising up to the front with its upright selector or gearshift lever, giving the interior the typical character of a cockpit upfront. The rear-seat bench moves fore-and-aft by 160 millimetres or 6.3”, with the backrest angle adjusting to three different settings.
Sales of the Cayenne in Europe are starting on 8 May, with Porsche offering the right model from the start for every customer: The range starts with the 3.6-litre V6 Cayenne. Despite the increase in engine power to 300 bhp, fuel consumption in the NEDC driving cycle in conjunction with optional eight-speed Tiptronic S transmission is down from the former model by no less than 20 per cent to 9.9 ltr/100 km, equal to 28.5 mpg imp.
The Cayenne Diesel with its 240 bhp (176 kW), 550 Newton-metre
(405 lb-ft) threelitre V6 likewise reduces fuel consumption by 20 per cent, down from 9.3 to 7.4 ltr/100 km (equal to 30.4 mpg imp now improving to 38.2 mpg imp).
.Fuel consumption is also down significantly on the high-torque Cayenne S with its 4.8-litre V8 power unit, in this case by 23 per cent to
10.5 litres/100 kilometres (equal to 26.9 mpg imp). At the same time the new engine delivers 400 bhp maximum output instead of the former
385 bhp, offering significantly better performance, just like all models in the new generation of the Cayenne.
This also applies to the Cayenne Turbo, with its 500 bhp (368 kW) 4.8-litre V8 biturbo consuming just 11.5 ltr/100 km (equal to 27.6 mpg imp) in the New European Driving Cycle, again 23 per cent less than its predecessor (14.9 ltr/100 km or 19.0 mpg imp).
Together with the Cayenne S Hybrid, no less than three of the five versions of the Cayenne thus consume less than ten litres of fuel per
100 km in the New European Driving Cycle, with two models emitting less than 200 grams of CO2 per kilometre. At 193 g/km, the Cayenne S Hybrid is not only the cleanest version of the Cayenne with the lowest level of emissions, but also the cleanest Porsche throughout the Company’s entire portfolio.
.In the intelligent interaction of the three-litre supercharged V6 and the electric motor, the Cayenne S Hybrid focuses on maximum efficiency from the overall system. Depending on driving conditions, the vehicle reaches this target with either only one drive unit operating by itself or with both drive units working together. In this context the 34 kW (47 hp) electric motor is of course the ideal partner for the 333 hp compressor engine with its high torque at low speeds. Together, the two drive units deliver maximum system output of 380 bhp and peak torque of
580 Nm/427 lb-ft at just 1,000 rpm, with the same kind of performance as the Cayenne S with its V8 power unit.
The two drive units are connected to one another by a separator clutch masterminded by the Hybrid Manager. Indeed, this separator clutch is essential to run the Cayenne S Hybrid either on its electric motor or combustion engine alone, or with both drive units operating together. Given a reserved, moderate style of motoring, for example in a residential area, this allows the driver to cover short distances on electric power alone and therefore absolutely free of emissions and with hardly any noise, driving at a speed of up to 60 km/h or almost 40 mph.
To ensure fast acceleration when setting off, the electric motor may however serve to provide additional thrust through its boosting effect. Intelligent management of the separator clutch makes the transition among the hybrid-specific driving modes most inconspicuous, comfortable and quick for the driver. At the same time the combustion engine may be completely switched off at speeds of up to 156 km/h or
97 mph, being fully disengaged from the drivetrain when no further power is required. In this socalled sailing mode, cruising along without power, the drag forces exerted by the combustion engine and their braking effect are eliminated in the interest of lower drive resistance and fuel consumption.
The prices of the new Cayenne models in Germany including national specifications and 19 per cent value-added tax (Euro base prices without national specifications and 19 per cent VAT in brackets) are as follows:
Cayenne 55,431 Euro (46,400 Euro)
Cayenne Diesel 59,596 Euro (49,900 Euro)
Cayenne S 72,686 Euro (60,900 Euro)
Cayenne S Hybrid 78,636 Euro (65,900 Euro)
Cayenne Turbo 115,526 Euro (96,900 Euro).
US Press Release:
ATLANTA February 25, 2010 Led by a technologically advanced full hybrid model, the all-new, next-generation Porsche Cayenne sport-utility vehicle will debut at the Geneva motor show in early March. In line with the Porsche Intelligent Performance philosophy, the entire range, from the entry level Cayenne with a V6 engine to the 500-horsepower Cayenne Turbo, all deliver improved performance while using less fuel and producing fewer emissions than ever before.
The New Porsche Cayenne will make its North American debut at the New York International Auto Show (press days: March 31 and April 1, public days: April 2-11). The Cayenne S and Cayenne Turbo go on sale in July as a 2011 model, and U.S. pricing will be announced soon. Porsche dealerships will offer the Cayenne and Cayenne S Hybrid in the fall.
The performance of a V8 with the fuel efficiency of a V6
The highlight is the new Cayenne S Hybrid featuring a highly sophisticated parallel full hybrid drive system. With a combined power output of 380 horsepower from the supercharged V6 combustion engine and an electric motor, the Cayenne S Hybrid combines the performance of a V8 with the economy of a V6.
Through continuous interaction between the 3.0-liter supercharged V6 and electric motor, the Cayenne S Hybrid focuses on maximum efficiency. Depending on driving conditions, either drive unit can operate independently or together. The 47-horsepower (34 kW) electric motor is the ideal partner for the 333-horsepower engine, which produces high torque at low engine speeds. With peak torque at 427 lb-ft at just 1,000 rpm, the Cayenne S Hybrid’s performance is on par with a V8-powered Cayenne S.
The Cayenne S Hybrid’s two drive units are connected by a decoupling clutch. A hybrid controller constantly coordinates their complex interaction, and intelligent management of the clutch makes the transition among various driving modes seamless. Like many hybrids, the Cayenne S Hybrid can cover short distances on electric power alone, free of emissions and noise up to 60 km/h or almost 40 mph. For aggressive acceleration, the motor provides an extra ‘boost’ to the gasoline engine.
What makes the Cayenne S Hybrid unique is its ability to cruise at high speeds on electric power alone. The gasoline engine can be completely switched off and disengaged from the drivetrain at speeds of up to 97 mph. Christened by the Weissach engineers as ‘sailing’ – or cruising -- mode, the drag forces exerted by the combustion engine and their braking effect are eliminated in the interest of lower resistance and fuel consumption.
All new-generation Cayenne SUVs set high standards for efficiency and performance. Compared with the former models, fuel consumption is down by up to 23 percent in the New European Driving Cycle and CO2 emissions are significantly reduced, despite the increased performance. Actual EPA-certified fuel economy figures will be available when the cars go on sale in North America in July.
A new eight-speed Tiptronic S automatic transmission with a wide range of gear ratios and the Automatic Start Stop function (first introduced on the Panamera) contribute to these improvements. So does efficient thermal management of the engine and transmission cooling circuits, on-board electrical network recuperation, variable deceleration fuel cut-off and the Cayenne’s intelligent lightweight construction.
New Cayenne sheds weight, gains space, yet looks more sleek and compact
Thanks to a special combination of materials as well as changes in the overall vehicle concept, such as a new all-wheel drive system, weight has been significantly reduced on all models. Despite an even higher standard of safety, the Cayenne S is 400 lbs lighter, which not only improves fuel consumption and lowers emissions, but also boosts performance, agility, and handling.
The completely new Cayenne design leaves no doubt that it is part of the Porsche family. Its sporting character is evident from all angles, and its Porsche shape and design highlights are more distinct than ever before.
The new Cayenne is 1.9 inches longer than its predecessor, and an added 1.6 inches in wheelbase ensures extra space and greater versatility. But despite larger exterior dimensions, the new Cayenne looks far more compact and dynamic.
Inside, the luxurious interior features a high center console that, like the Panamera, rises up at an incline to meet the dashboard center stack with high-quality fittings and a touch-screen infotainment interface. Porsche’s traditional set of five round instruments in the drivers gauge cluster includes a high-resolution circular TFT screen to the right of the tachometer. It can be used to change radio stations, vehicle settings, or access the navigation system or view the map. Rear-seat comfort is much improved, as well. The bench slides fore-and-aft by 6.3 inches, while the backrest can be adjusted to three different angles.
The Cayenne V6 and V8 engines are more powerful and more fuel efficient
The entry-level Cayenne with its 300-horsepwer 3.6-liter V6 engine and mated to the new eight-speed Tiptronic S automatic transmission consumes 20 percent less fuel in the New European Driving Cycle than its predecessor.
Fuel consumption is also down significantly on the high-torque Cayenne S. Its 4.8-liter V8 produces 400 horsepower, 15 more than the previous model. When combined with the overall weight savings, performance is markedly increased, yet fuel consumption is down by 23 percent in the New European Driving Cycle.
The Cayenne Turbo, with its 500-horsepower, 4.8-liter twin-turbocharged V8 also consumes 23 percent less fuel than its predecessor despite its improved performance and acceleration.
Together with the Cayenne S Hybrid, three of the new Cayenne models produce less than 200 grams of CO2 per kilometer. At 193 g/km, the Cayenne S Hybrid is not only the cleanest Cayenne model, but also the cleanest vehicle in Porsche’s entire portfolio.
About Porsche Cars North America, Inc.
Porsche Cars North America, Inc. (PCNA), based in Atlanta, Ga., is the exclusive importer of Porsche vehicles for the United States. It is a wholly owned, indirect subsidiary of Dr. Ing. h.c. F. Porsche AG. PCNA employs approximately 180 people who provide Porsche vehicles, parts, service, marketing and training for its 200 dealers. The dealers, in turn, provide Porsche owners with best-in-class service. Throughout its 61-year history, Porsche has developed numerous technologies that have advanced vehicle performance, improved safety and spurred environmental innovations within the automotive industry. The company continues to celebrate its heritage by adding to its long list of motorsports victories dating back to its first 24 Hours of Le Mans class win in 1951. Today, with more than 28,000 victories, Porsche is recognized as the world's most successful brand in sports car racing. PCNA, which imports the iconic 911 series, the highly acclaimed Boxster and Cayman mid-engine sports cars, high-end Cayenne sport utility vehicles and the four-passenger Panamera Gran Turismos, strives to maintain a standard of excellence, commitment and distinction synonymous with its brand.
I like it!
It feels more sporty to me from the previous version. Curious if this is still built on the Toureg or now the Q5 platform... It feels smaller than the one it replaces... I'm sure it's just me though.
:cheers:
I like it!
:cheers:
It does look a little smaller in the photos even though it is "is 48 mm or 1.9” longer than its predecessor."
Anyone want to be one of the first on the list?
Porsche Prophet
If you reviewed the YouTube ad on the Cayenne (very cool looking...may be my next truck), it is interesting to see that this is the second "new" model that has the old P O R S C H E lettering with the model designation under it just like the new Panamera...
I think this is a good direction for Porsche. The Cayenne inevitably got compared to the X5, despite it being a "real" off-roader" with an actual dual-range transfer case. And let me tell you, the GTS manual in low-range is geared lower than any 4x4 I have ever experienced; but to what purpose? Even though I use low-range about once a month mainly for mud, hill-climbing and sand; with all the plastic tangly bits, I and any sane person, will avoid things like rock-crawling where the low gears make sense.
A did hear a rumor that they will offer a dual-range in the "off-road" technology package. Going forward, I'm really interested in a diesel Cayenne
i think the new shape is hot (regardless of old lettering/new lettering(?)...) and i also would like to see a diesel model here in the US.
in time.. it will come...
:banana:
GO PORSCHE!!
Sexual Philanthropist
If they offer the same offroad package as the touareg is getting as an option(which is likely), they will get a gearing reduction at the center differential, which is said to be not as extreme as the previous generation nor as robust apparently.
One thing for sure, if they come close to duplicating the interior of the Panamera, it'll set a new standard for it's class.
Even though I'm not in the market for one, I hope it'll be a huge hit for them.
This engine comes from the Audi S4 with an additional hybrid-module.
Tamas
Not in love...but ike it more than the first generation...not very fond of this Porsche segment, maybe i'm just a traditional guy that can't see a Porsche without that sportif coup look :crazy::crazy::crazy::crazy::crazy::crazy:
As a current Cayenne Turbo owner, gotta say I love the new one! Not yet in the market for a replacement for mine, but am pretty sure it will be another Cayenne Turbo. As for the "segment," this segment makes Porsche money that helps the overall company bottom line (so they can continue to make our Caymans and Boxsters, and 911s), so I love it!
I really like it. Bummed that we won't see the Diesel here early (if at all). Since I do get onto some gnarly roads from time to time I am very happy to see this with better mileage even with the gas engines. Keeping a close eye on this one.
1 - 20 of 43 Posts
