To my knowledge, lovetoturn still is using the same setup of PASM shocks and X-73 springs after 4 years of service.
Lovetoturn bought a 2021 GT4 and passed his Cayman S down to his son. I saw him at a DE last month at Eagles Canyon (Texas).
It's good to have a baseline with a good driver in your car, or similarly-equipped car, to know what the car is capable of, and where the driver needs to improve. Comparing video and data against their line, braking and acceleration really goes a long way to knowing what to work on.
IMHO - I'd spend a little money on data to improve the driver, before upgrades to improve the car.
I started with a phone and Track Addict, then moved to an AIM Solo DL, and now I've paired the AIM with a Garmin Catalyst.
You really need something with data quality like an AIM to compare driving lines, braking and acceleration. The phone GPS just doesn't have the accuracy. If you know better drivers running the same track in similarly-equipped cars, you can learn a lot by sharing data and learning what they do.
If it's just you out there, and you don't have anything to compare to, you don't get quite as much out of the data. That's where the Garmin comes in.
The Garmin Catalyst is great for fine-tuning your driving. If you try different lines and braking, it can help you put it all together to turn a more consistent lap. The best part about it is that it helps you examine your consistency with video coupled with data, and gives you things to work on immediately after getting off the track (and even when you're still on the track with the advanced coaching audio).
After your session, it'll give you three things to work on. It will perform an analysis of what you did in particular corners that improved your time (brake 5 feet later, brake lighter, apex earlier, enter at 3mph higher speed), and will show you video of your optimal line. With a touch of a button, you can also see your entry for a particular corner on every lap of the session.
The one thing it can't do is tell you how to improve by doing something you haven't tried. It only uses your personal performance. So, you need to spend at least a session trying different things and let the Garmin help you figure out what worked and what didn't, and how to put it all together.
Note: The Garmin doesn't replace the AIM (yet) for data analysis. You can't look at the squiggly lines. You only see what the Garmin wants you to see. There is no way to export the data, only the video.
I've been DE'ing about 5 years in my 981 and purchased a 1995 BMW M3 racecar about 18 months ago. It's rocking a whopping 213 WHP max (w/restrictor plate). However, I can now turn a faster lap in that car, albeit with slicks, than I can in my 981 BS on street tires. It wasn't so when I first bought that car, but seat time made a huge improvement.
The co-owner of my racecar can still turn a couple seconds faster in the BMW than my 2:10 lap time at ECR. He's been racing for ~20 years and is one of the top drivers in NASA Texas. I'm lucky being able to share the car with him and learn from his data. We swap off in the car, and I run the AIM and Garmin for both of us. After a session, I'll compare our data so I can see what he's doing to turn a faster lap. He carries ridiculous speed through corners, and that's where he gets most of the time, but I can see what the car is capable of and start pressing those limits a little farther.
