1 - 2 of 2 Posts
Black Friday Starts Now at APEX!
This year to give thanks to our loyal customers we're offering stellar discounts across all of our popular lightweight flow formed SM-10 wheels for Porsche. Plus, add Michelin PS4S or PS2 max performance summer tires, or Nitto NT01 r-compound track tires to your order and get free mounting & road force balancing ($100+ value).
We developed the 18” SM-10 Porsche wheel line a couple of years ago to meet the diverse needs of the Porsche performance driving community. The SM-10 wheel design offers new and exciting aesthetic and functional features that build on existing APEX principles: Strong, Lightweight, Affordable. Weight is reduced by CNC machining material out from the spokes to give an “I” beam design. To top it off, these wheels feature massive brake clearance which allows them to clear OEM 996 & 997 PCCBs and a variety of aftermarket big brake kits that many other 18” wheel manufacturers simply cannot accommodate. Whether you are are a street customer looking to upgrade your stock wheels, or a hardcore track enthusiast/racer who needs wheels that can withstand track abuse, we have you covered.
Don’t wait to place your order, these won’t last long.
These deals are valid from Wednesday, November 27th through Monday, December 2nd @ 11:59 pm Pacific.
Visit Our Website to Order
Designed For The Performance Enthusiast
Fit Matters
The right solution for every application
These concave SM-10 wheels are designed specifically for your Porsche. The SM-10 provides chassis optimized fitments and proper load distribution. If you’re looking for a cost-effective lightweight 18” wheel, this is your answer.
Face Profile
One design, many levels of beauty
The SM-10 wheel was created in three increasingly-concave face profiles; The shallowest face provides maximum caliper clearance on narrow applications, while the deepest concave face reduces weight and creates a stunningly aggressive appearance on wide-width applications.
"I" Beam Spokes
More than just a pretty face
The spokes of the SM-10 were designed to be robust where they need to be, and extra lightweight where they should be. Weight is reduced by CNC machining material out from the sides of each spoke. It’s expensive and avoided by almost every manufacturer, but affordable with volume. In each concavity profile of our SM-10 design, the I-beam spokes are carefully evaluated from structural aspects to ensure minimal weight, brake clearance, and remarkable strength.
Beefier Lip
Ready for more abuse
By saving weight elsewhere, we’ve added extra material where it counts. We’re beefing up the barrel’s inner lip on the SM-10 to better handle the repetitive abuse seen on the track.
Knurled Bead
Keep a true balance
We’ve upgraded these wheels to include a knurled bead seat to reduce unwanted tire rotation. This added feature will help keep your balance stay more true throughout the life of the tire.
Brake Clearance - Barrel
A lot of room in a tight space
Spoke clearance is only half the problem. The barrel construction on a wheel also needs to be big enough to clear the sides of your caliper and rotor. Many aftermarket wheels that have aesthetic compromises in their design may work with smaller stock brakes, or smaller diameter big brake kits, but the larger kits will pose a major problem. Targeted at the serious performance-minded owner, 18” SM-10 wheels clear up to 380mm rotor, 6-piston brake kits including the factory PCCB’s.
Open Hub Center
Easy to access lugs
Race wheels can't just be light, they need to function in a high performance environment. Unlike the narrow lug recesses of most other wheels, the SM-10 wheel features a wide open hub center that easily accommodates oversized race lugs and beefy impact sockets. This allows for quick and easy wheel changes and prevents chips and scratches from tools.
Hub Centric
No rings or adapters here
All APEX wheels are purpose-built for select vehicle applications, and centering rings are never required for any Porsche application. All 5x130mm bolt pattern wheels feature a direct-fit, 71.6mm center bore.
Center Cap
A factory fit and finish
We don't reuse one cap design for all of our wheels. Every SM-10 wheel is designed to work with factory center caps. You can easily replace APEX center caps with OEM Porsche crest caps for a clean factory look. The SM-10 wheels will ship with our Gloss Black center cap that mimics the size and shape of a Porsche factory center cap.
Wheel Hardware
Original or Aftermarket, it all works
The SM-10 Porsche wheel can be used with all OEM and aftermarket mounting hardware with a ball seat lug recess. Lug bolts, wheel locks, and stud conversion kits all work perfectly. The SM-10 wheel also accepts wheel spacers without issue. The shallow rear chamfer allows the wheel to remain hub centric even when 5mm flat spacers are used. The chamfer is deep enough to clear the chamfered lip found on some aftermarket spacers that would typically cause improper seating of the wheel and, therefore, wheel vibration.
TPMS Sensors
They all fit
TPMS sensors, which monitor tire pressure, are one piece of technology that can't be compromised. All APEX wheels accept OEM and aftermarket equivalent Porsche/HUF TPMS sensors, and any standard sized metal or rubber valve stem. Use the chart below to help select the correct TPMS for your vehicle.
The APEX Standard
1. Weight & 1. 1. 1. Strength Optimization
It’s all in the details
We didn’t just redrill and recycle our 5x120 SM-10 design, we’ve rebirthed it. After seven months of Porsche-specific optimizations, we’ve minimized weight while maximizing strength. Strength tested to JWL/VIA standards. Since most Porsches have an inherent rear weight bias and run wide rear wheels, we’ve strengthened the inner lips. The result is a lightweight wheel with extra strength in all the right places. Use the SM-10 with confidence on both street and track.
2. Flow Forming
Benefits of forging, without the pain
These APEX wheels are produced using a manufacturing process known as flow forming. This process significantly reduces weight in the barrel, which has the greatest impact on rotational mass. During the manufacturing process, rollers apply high pressure to the inner barrel, compressing the aluminum into its final shape. This effectively eliminates porosity and aligns the grain structure of the metal, which increases tensile strength. The end result is a lightweight and extremely strong barrel that equals that of a traditional forged wheel at a fraction of the cost.
3. Testing & Certifications
Verifiable 3rd party testing
Many companies promote their wheels as being certified by the VIA when they actually aren’t. That’s like using the USDA logo on food without permission. APEX wheels get officially tested and registered by the VIA in Japan, and we have the proof to back it up. Learn more about false VIA claims.
Japan’s JWL is a commonly followed standard for wheel load ratings. Our flow formed wheels meet, and most exceed, their load rating requirements. Most manufacturers only meet the minimum while some don’t even do that. Check and verify load ratings before you buy. Learn more about wheels that aren’t JWL.
Tire Mounting & Road Force Balancing Service
For your convenience, wheel and tire packages are now available at APEX. Our knowledgeable Porsche Product Experts hand pick some of the best compounds available from prominent brands like Michelin and Nitto, and we’ve priced them competitively. All wheel and tire packages include free mounting and road force balancing by our trusted enthusiast technicians. We use high-end, touchless equipment and inspect every wheel and tire combo thoroughly before they leave our warehouse.
*Note: Tires will only ship mounted to the wheels in your order, and can not be sold separately. Tires and wheels must be purchased in the same transaction. Tire-only orders will be canceled and refunded.
Fitment Questions? We know what fits.
From direct bolt-on to all-out race fitments and everything in between. We've street and track tested extensively to save you the trial-and-error. Click here for a one-on-one consultation with one of our product experts
Lifetime Warranty
All APEX wheels come with a lifetime structural warranty and 1-year finish warranty, so you can be confident in your purchase. Learn more
APEX360° Wheel Replacement Program
Let’s face it: Whether you are a weekend warrior practicing at the track, a club racer pushing the limit for a podium finish, or your daily commute involves crater-ridden minefields known as city roads, mistakes happen and parts will be damaged along the way. We are not really a performance company if we sell wheels in a way that penalizes the pursuit of driving at the limit. For this reason, we stepped up and created a program to significantly reduce the costs of properly maintaining a set of wheels by making replacements extremely affordable.
Our unique APEX360° Wheel Replacement Program offers eligible customers replacement wheels at 50% off our standard prices. Learn more
Contact Information
Discussion Starter #2 (Edited)
That's a wrap, folks! Thanks to everyone that participated in our Black Friday sale. We look forward to seeing you and your wheels on track in 2020.
1 - 2 of 2 Posts
