I'm getting a clicking sound from the front area of the passenger seat or floorboard. Sounds something like an electric switch cycling. Seems more prominent in turns. Only occurs when motor is running and I am driving the car--not the sound of engine/exhaust cooling after shutdown. Car runs fine.
Any thoughts? :crazy:
Not too much to go on. Whenever I have a noise such as this, I will have my wife drive the car while I do a better search for the noise.
When the noise is happening are you using the heated/ventilated seats?
Would the A/C compressor on the fritz make such a sound? Try driving a bit with the A/C turned off and see if that makes it go away.
ZONE 1 Member
I suspect you may be having a problem with the Bose amp located under the passenger seat. Take it back to the dealer for a check.
