1 - 14 of 14 Posts
Hello!
My 2006 Cayman S with 150000 km is still running strong. No noise on cold starts, no noise at idle and no noises while normal driving. When i run the enige at high revs i get a ticking/tapping noise. Sometimes it starts at 5500 rpm and some times it starts at 7000 rpm.
Yesterday i noticed that the noise disappeared after several hard/high rpm accelerations. Went on the highway in 100 km/h fore about 10 minutes, then floored the pedal and the noise was back again. Watch the video (sometimes it is louder than this). Any ideas?
Video: Noise high rev
2006 Porsche Cayman S
Hello!
I have a 2006 Cayman S with exactly the same issue. It’s at the dealer now but they haven’t been able to replicate the problem. I’m going to send them the link to your video. I will let you know if they are able to diagnose what’s causing the noise.
Sounds like a loose baffle in the exhaust - unless the car has had any exhaust modifications - then..
Change your motor oil to a 5W-50 brand, like Castrol Edge 5W-50 or Mobil 1 FS 5W-50. If the noise is a rod bearing, you can prolong your pain with this motor oil. I would also use some Prolong or Extreme oil concentrate just to be sure you are not scaring a rod bearing. This a a $10 k issue, so change the oil and cut open the paper filter to see if you have piston flakes or metal of some sort in the filter billows. You can also get an oil analysis done by either blackstone or LN/BRS who will send you a kit.
Discussion Starter #7
Hope you are wrong but yes i found some smal metal flakes in the Oil filter.
268083
Discussion Starter #8
Any News on from your deler about the noise?
They were unable to definitively diagnose the cause of the noise. They adjusted a heat shield on the exhaust and it does seem to have helped.
rogerbjerk- Some of those flakes could be piston coating, not metal shaving. If you have a magnet on the drain plug, and have a lot of tiny thread type filaments around the magnet, then you could be seeing some metal breakdown on the timing chains. LN or Blackstone oil analysis could help you determine where the metal is coming from. The other noise could be in your induction system. You have a resonance valve that controls the harmonic pressure wave which usually has no sound, but it may have broken. Not sure, but it does not sound like a rod bearing or piston wrist pin at least to me.
Discussion Starter #11
Got my scope camera in to the cylinder through the drain plug. Engine going out i gues :eek: Could this make the high rev noise?
269868
Yikes, that looks pretty bad! Is it using oil or smoking? You say power is still good and its a 150,000 km motor, so Im wondering if you shouldn't just use a thicker oil and keep driving it for now if you aren't having to constantly put oil in it and its running fine? Squeeze every bit you can out of it if you plan to keep it and invest in a rebuild anyway. Maybe it last a week or it could last another year or more since you dont really know how long the scoring has already been there. The end result will be the same either way
The cheapest fix is a junkyard motor. I'm not an expert on these motors, maybe someone who races in Spec Cayman can give the OP some ideas on how and what to look for to get the best motor off the rack. Most of the time, they are stored on a floor or in a rack, so no idea about how they were cared for or how many miles are on them. But the Spec Cayman group says these engines are good for about 80 hours of flat out racing.
So for $5000 you may score a 3.4 or even better a 2.9 that will fit and even have a few extra parts between motors to put together the best clutch package and water pump before installing. The 2.9 still uses the Bosch ECU and is better able to withstand the bore scoring issues.
Hope you are good with wrenches and have a place to replace the motor. Rebuilds start well above this price. Good luck. Run some 10W-50 oil that will stick to your scored walls. the idea is to keep the piston and cylinder walls separated. Most likely if you do run your motor, you will need to change the oil often. There is an oil blog called RAT/540 looking at these issues, so an hour or so of oil research may pay off and allow you some flexibility as to when you need the next motor.
1 - 14 of 14 Posts
