Just a FYI for those doing their own oil changes, you may need more than 8 quarts.
Just did my 3rd oil change on my 2015 2.7 Boxster, at 13,450 miles, and the results are similar to the last change.
Prior to this oil change, I had 2 green bars on my dumbstick. I was up to three bars at 9000 miles, my last change and never added any oil
Proceeded to drain 8 quarts, including the filter oil. I weigh my drain oil due to problems in the past. See older posts, hence the term "dumbstick."
Added 7.5 quarts, drove a bit to warm the oil and now have the yellow triangle and the message "Oil level at minimum"
Added one quart, now at two green bars and 8.5 quarts added.
Added another 1/2 quart, now at three green bars and 9 quarts in.
I still had 8 ounces (1/4 quart) left in the 5 quart jug and added that.
Now I still am at three green bars and 9.25 quarts added.
All measurements were in the exact same space and I waited for oil temp to reach 185F, shut engine off for one minute and took a reading.
BTW, The engine actually holds over 10 quarts; it just does not all drain into the pan. I normally let mine drain for 2 or 3 hours.
