Re: 981 Oil Consumption Between Oil Changes
You didn't specify what was the level after the oil change. If it was full (4 bars), seems above average, but if you ask Porsche, anything less than 1 freaking quart per 1K miles is 'normal'. It's obviously not, but that tells you the uphill battle that such fight is with them. In your case, 1.8-qt (Max. It's probably less than that, since it's hard to fill up the 4th segment, and you might not get to the yellow one. Each segment is 0.45-qt) in 5K miles is definitely in the true normal range, but on the high side for sure, for what I've read here. I put 5,500 miles on my oil, and level didn't move from 4 bars (and got 9.25-qt out, so nothing fishy), and I also drive my car aggressively most of the time (not near redline, but both upshift/downshifts in the 4-5K rpm constantly, which is where the engine sounds awesome with PSE open. It was a nice surprise that my engine doesn't burn any measurable oil. Put back 9 qts just last week, and still showed 4 bars, so left it there, but probably just barely triggered the 4th segment, which is perfectly fine with me. I just removed the extra quart (on a Porsche bag) from the cubbie behind my seat, since will never use it. Remember you could change oil viscosity depending on your climate, to minimize oil consumption. Based on the many years reading about that, I'd say about 1-qt for every 5K miles is about the average consumption IMO. You're probably at the 1.5-qt level, which is not alarming by any means. I'm at the other end, fortunately, but by your description, you seem to drive harder than I do, which obviously increases oil consumption. That's why it's hard to set a figure, since it depends a lot on driving style. I wouldn't worry about it. But if you live in fair weather year long, you could switch to 5/50, like many have done. Do a search to get more details. Good luck.
