1 - 9 of 9 Posts
I am wondering is it normal to see a slight bit of oil in the exhaust tube ends? It is hardly any but I noticed it before and wiped it away and now it is back very little though???
Are you sure it's oil and not water and soot? Hard to imagine oil making it through combustion, catalytic converter and muffler to make it to the exhaust tips.
How does it feel ?
We need more information about your oil consumption, does the oil or whatever smear when you try to rub it off or is it tar like? Does your car smoke on startup? Usually your cats will take care of /burn any oil, except for startup smoke. That is unless you have a catless exhaust, which then you may have some oil residue on your tube ends.
Discussion Starter #7
I will have to check...
Kind of dry if I remember correctly...
That's normal. Condensation in the exhaust after sitting for a bit will mix with the soot and can spit black water droplets out of the tips on initial startup. The water in it will dry leaving a dry, powdery soot on the floor. That is not what oil in the exhaust looks or feels like. Oil will always be oily.
My garage floor has a light grey epoxy coating on it, and I keep a small rug under the rear bumper to catch these startup soot drips.
Ok great, thanks I will check it out
1 - 9 of 9 Posts
