41 - 46 of 46 Posts
2006 CS manual
I used 1-1/2 in equus 8000 series gauges, only thing is they don't have oil temp ,so I used water temp instead. at least I know what it is.
they are electric so U just need to install senders instead of hard lines. etc. I can send you the BOM I used.
pm me
I used a Depo Racing gauge kit (Oil Pressure, Oil Temp, Water Temp and Voltage) in the Sport Chrono pod to give me some visibility into oil pressure and oil temp. View attachment 207557 View attachment 207559
That’s a clean install. What’s the part number for the kit?
I think I found it. It’s Depo Racing part number: WA60274B
https://fcp-engineering.com/en/wa-60mm-4in1-series/372-depo-racing-digital-60mm-4-in-1-gauge-boost-oil-temperature-oil-pressure-voltage.html
Did you manage to get all the gauges working properly? They really add information to our dash. Not sure I would be accomplished enough to get this done. First I would need to find the dash cluster in a wrecked 997, then get the right transducers to send oil pressure and oil temps to the dash.
41 - 46 of 46 Posts
