Hi, My temperature sensor showing the outside temp is stuck and does not change or display correctly, is it the small plastic piece on the passenger side front bumper on the inside? how easy is it to replace it? has anyone had similar problem or have replaced or fixed it. Thanks, its a 2014 Cayman S.
Might be an electronic or software issue. I'd take it to the dealer instead of messing with it and then them blaming you for it.
