I am in the process of purchasing a Spyder and the dealer provided the following over rev report. Please advise if this looks good. I did some searching and from what I see it appears good unless i'm missing something.
Thanks in advance.
Derek
View attachment Over Rev.pdf
The report is good. The number of revs in range 1 were because of the engagement of the rev limiter. The rev limiter shuts off the fuel supply when the revs are at or near red line, but it may take a tenth of a second to engage. Hence, the range 1 over revs and a small spillover to range 2.. Range 4 and above over revs are problematical.
Appreciate the quick response. Guess that means I can pull the trigger and move forward. Goodbye Boxster S, hello Spyder :)
No issues with those overrevs...although the report is incomplete as it doesn't show total operating hours, nor the VIN. Is the report being provided by a dealer, and are you SURE it's the overrev report for the car you're buying?
Reactions: RickH
I'd be wary of any dealership showing you a report that doesn't show the actual VIN. This is very easy for them to send to you as a PDF, I just received one recently, and the VIN + the rest of the report (showing any fault codes, etc.) came with it. Agree with everyone, any overrevs in 1 - 2 are fine / normal, someone just drove it to redline / limiter a couple times.
