1 - 2 of 2 Posts
Position of crankshaft in relation to intake camshaft
NOTE
This fault is entered if there is a permanent deviation from the nominal
value of 10° camshaft angle.
Diagnostic conditions
Battery positive voltage 10 ... 16 V
Engine idling
Camshaft adaptation has taken place
No fault in camshaft sensor
No fault in crankshaft sensor
Possible fault causes
Camshaft sensor faulty (internal phase shift)
Solenoid valve for camshaft adjustment soiled (does not close fully)
Timing set incorrectly
1 - 2 of 2 Posts
