Well after almost a month of trial and error and multiple trips to the dealer my PCM 3.0 Nav upgrade/retrofit was reversed by my dealer last week. Seems as tho while you can order a car with Sat XM radio, PCM 3.0, and Nav and bluetooth/ipod/aux; you can ONLY order the retrofit with PCM 3.0 and NaV. I lost my SAT XM radio and my bluetooth and ipod couldn't be re-coded to work on the new unit. So I had them switch back to my old PCM 3.0 and viola I had all the above working except of course NO NAV.
My service mgr said that Porsche AG had issued a new service bulletin specifically regarding PCM 3.0 NAV retrofits (due to my car) and what they experienced. Hey I want royalties! LOL I guess we are the guinea pigs out there huh but I think my dealer is getting a little tired of learning with my car...such as the earlier lesson they learned that PSE installation in a 2009 C2S does take longer than 3.5 hrs as the cars are NOT fully wired from the factory IF PSE was not ordered originally! LOL
For those curious on price...My kit cost $4200 parts, install, taxes. That was after using a 20% discount coupon that Porsche NA put out last month that ended 31 March that my dealer honored. I believe Suncoast's kit is $3900. So it is not a cheap upgrade but one I was willing to try.
BE ADVISED however that you will NOT be able to get a unit with Sat XM and that Bluetooth/ipod should work but mine did not this is from Porsche NA. These functions are built into the PCM circuit boards/units so they come specific to the PCM 3.0 unit it seems. Also ALL enabling codes for NAV and those functions are held by Porsche AG in Germany and MUST be obtained WITH each unit (they are specific to the UNIT and VIN) and used to unlock those functions. Without the secret envelope (I am serious) with those codes your unit will NOT function. Trust me it took 3 trips to the dealer to figure this out and multiple electrons between my dealer, Porsche NA, and Porsche AG. Also be advised that your old PCM 3.0 MAY NOT work in another Porsche if sold and an install is attempted into the new car as the coding may not match the VIN and may disable the unit or leave certain options nonfunctional. Porsche NA's explanation for this was security/theft protection? Personally I think its just plain nuts and paranoid/schizophrenia or something! But they are the boss in this matter I guess. So the e-keys to PCM 3.0 kingdom do lie securely in Germany my friends. This may also explain why no Aftermarket Sat Radio and/or Bluetooth options have appeared yet on these cars while multiple ones (Denison, mbridge, etc) exist for PCM 2.1-2.3 units out there for those who want them. So while each case may be different; it seems that the PCM 3.0 isn't just a simple plug in play change out and if your shop is doing one for the 1st time you may want to come back after they've done 1 or 2 of em and figured out the kinks in things rather than be the 1st one to be done. IMHO
SO I got my $$ back and will wait for them to unscrew this mess and make it more readily available before I try again. A Garmin costs 90% less and does the same job when I need it and I use Sat radio and bluetooth/ipod much more than looking at the map and watching Nav announce turns. Aftermarket was an option as I did with my 2009 Boxster but I decided to keep it real and original.
Yes folks are right in that it is cheaper to buy the car with NAV installed from the factory...also alot less headache producing too! Good luck. Any questions feel free to PM me. Rob
