The PCM on my CPO 2013 BS without memory seats loses some of the navigation and stereo settings after turning the car off. The guidance volume, map preferences, stereo settings for the balance, fader, etc are not recalled after the car is shut off and restarted. When the car is restarted the display shows a message "calling up settings for key 1" but the navi and stereo settings always reset to default, not where they were last set when the car was turned off. There is no auto-memory setting to check in the settings menu to enable this function. The car has been at the dealer for the past 10 days, fortunately under warranty. They reset the PCM, replaced the PCM (Ouch$!$) and said the memory settings for the key DID work properly but when they installed the latest map software the memory function for each key no longer worked. The dealer is clueless and they have escalated this to Porsche NA. Anyone with a similar situation?
