Hi all
I was wondering if anybody has a step-by-step of strip down and re-assembly of the brake/clutch pedal assembly for my 2007 Cayman please? When braking with the clutch pedal releasing i get a movement feel on the clutch pedal. I also can feel movement in the brake pedal at the same time. Having looked at the parts diagram i can see that both pedals pivot on a shared axle, each mounted in a pair of bushes on the axle. I think these have worn and so producing lots of play when actuating them. My clutch pedal also sticks sometimes on the last 10mm of release travel. I’m going to replace the bushes and rubber stops on the whole assembly so a SBS or even video would be a great help. Or indeed any tips/words of wisdom?
Cheers, Rob.
