Porsche Cayman Interseries Racecar
Are you ready to graduate from a track prepped street car to an all out race build? Then this Cayman is for you! It started life as a Cayman Interseries racecar and has been upgraded with a wide variety of new equipment since then:
- 11,000 miles
- 1.75x .95 DOM roll cage painted white
- Nascar driver's side door bar
- Easy entry and escape, driver's side rocker bar
- Fire system cable pull
- Battery external kill switch pull
- Cool suit cooler
- Recaro spg hans drivers seat on sliders
- Schroth Hans 6 point pull-up belt system, expires 2021
- MOMO Mod 78 350 MM steering wheel, quick release hub
- 14 in convex rear view mirror
- AIM MXL Pista data logger/display with Can interface
- Cooling system overhaul 2017
- Lightweight flywheel Aasco 2016
- Front and Rear Control Arms - Tarrett competion
- Front toe link-ERP with bump steer
- Front diagonal link-ERP with anti-dive adjustment
- 29mm, 5 position adjustable, tarrett adjustable end-links
- TPC rear sway bar, 23 mm, 4 position adjustable, tarrett adjustable end-links
- Front brakes-Stop Tech ST60 caliper with hawk dtc 70 pads
- Rear brakes-stock Cayman with Project hawk DTC 70's pads
- Custom rear brake ducts
- 997 GT3 master cylinder
- Porsche Cayman S 6 speed manual gearbox G87/40
- Gear box air-to oil cooler, with Tilton pump, fan cooled with switch control
- Switchable factory PSM
- Getty front splitter, Painted body color
- Front hood pins with secondary latch
- Stock rear hatch with Cayman Interseries wing base, 55" Cayman Interseries.
- 6-Speed Manual Transmission
- Guards LSD
- All fresh fluids 2017
- Meticulously maintained
Ready to take to the track 100% sorted!
KMC specializes in maintenance, custom fabrication, and track day support for Porsche race cars. We also service and customize high performance exotics, from Ferrari F40s to Noble M400s and beyond. You can check out our credentials here:
http://kmcauto.com/
We are confident in the stellar quality of our automobiles, and our prices reflect that. Low ballers will be ignored. However, if you?re willing to stop by the shop for a test drive, we?re happy to negotiate with you. Please feel free to call or text our sales phone at any time:
617 676 7000
You can also send us an email at:
[email protected]
Thanks!
List Date: 7/26/2017
For more info, click here to view the original listing: Porsche Cayman Interseries Racecar
This item is no longer available.
