Does everyones power windows still operate whenever the doors are open with no key in the ignition? If the doors are closed (no key) the switches don't operate the windows, but as soon as you open the doors you can roll the windows up and down without a key in the ignition. I didn't think this was normal... This is a 2012 Cayman S.
carlj, I tried the same thing in my 2009 and yes, I too can lower/raise windows with the key out and door open.
mine has the feature of lowering and raising the windows via key fob too - not sure if this is standard or some kind of option, and if has any effect.
I found this an interesting read on power supply of the car....
Cayman Technical Data
Thanks for checking! Great technical spec thread, appreciate the link! Thought I may have a faulty module.
