Im trying to build a street worthy ASP car from my 2010 S with PASM. Something that doesnt shake my eyeballs out of my sockets on bumpy mountain roads where I live. Here is what I have done so far.
Tarret hollow GT3 bars front and rear 4 and 5 position adjustable.
Tarret endlinks
H&R sport springs
Lightweight Assco flywheel and Sachs Sport Clutch
18x10 rear and 18x8.5 front lightweight Enkei wheels
Currently running Hankook Z221 265/35 front and 295/30 rear.
Car rides very nicely. I have noticed that if I go too firm in rear lack of LSD gets exgerated and on long sweepers its harder to get power down. But without more rear bar car understeers a little. Perhaps too much stagger on tires? What would you reccomend in terms of swaybar settings? Car does push a little more but at much higher limit. Current setting is at middel of 5 way adjustable front bar and one back from full firm in rear. Im thinking of going to softer front and rear settings .
Im moving to BFG R1 S 275/35 front and 285/30 rear for my first National Tour Event at Crows Landing. Hoping that gives me a little more turn in than 265/295 combo im running now. Looks like another Cayman S and Evo so far in ASP.
Are there any cheap quick things I can do to improve my car in ASP class other than change the nut behind the wheel? Its been a while since I have read SP rules.
I don't AX but I do run the Tarett bars. With 500# F and 600# R springs, my front bar is 1 off full soft and my rear bar is 1 off full stiff. I am lowered about 1-1/2" and run a Guard LSD. I run BFG R1, 245 F and 275 R. Alignment is -3.4 F and -2.6 R camber, 0 F toe, 1/16" total R toe measured on the rim. This is a very fast set-up on a DE track.
Thanks! I started off with moderate camber -2.5 and -2 rear. I run 1/8 toe out up front and 0 rear. I'm considering OS Giken LSD for Autocros.
Spent some more time in the car at local autox and now most apparent issue for me is the lack of LSD and the overly intrusive PSM/ABD. I can feel car slowing down as systems engage and I really don't like inability to kick rear end out with throttle.
i think I have read that if I disconnect yaw sensor electronic dif controls are disabled. Any good install pics for a on/off switch? Seems to me that should be fairly easy project and give 100% control of the car back to me. I just hate not being able to get rear end to rotate in some situations. While electric systems are good I like being able to point car on my own with throttle responses.
Do a search on the yaw sensor. I can't reference the article but if I remember correctly you put a switch in the yaw sensor ground wire.
Grant,
Curious: is your car equipped with 'sport chrono'? In 'Sport+' mode PSM is far less intrusive. I've been fiddling with a combo of 'Sport+' and PSM on/off at a recent autox. Best times I post were with 'Sport+' on and PSM off. Running without Sport+ was noticeably slower and I could plainly feel the stability system going nuts. That said, my car is equipped with an LSD so and PDK.
DJM
The yaw sensor on the 987.1 cars was behind the driver side radio console side panel. You could see the sensor and access the brown/blk ground wire to interrupt it. Not sure where the 987.2 location/colors are. But... with PSM disabled like that (essentially throwing a fault) you cannot engage PASM Sport, or Sport modes - that was how my 987.1 reacted. So you are stuck with soft throttle response, and with a pdk, commuter shift strategy.
I have used Guard diffs in both of my cars, and have been very happy with the quality and performance. The clutch diff Matt/BGB setup for our PDK car works flawlessly, and the car is balanced at all speeds. It has survived a full season of pro solo and testing launch control launches with 2 drivers as well. Install has been very simple, as I mentioned in my other posts.
