Hello, I installed the PSS9 on my cayman 987, what settings do you recommend? I use my cayman 80% road and 20% on the track! Sorry for my bad English ;-)
Fede
Boxster Enthusiast
I used to change settings before and after DEs. Now they are set to 5 all the time.
Easy to change setting before / after track events... just don't stick your hand under there ungloved right after you come off track! :eek:
Full soft on street. One click off full stiff on track, or sometimes a few clicks off full stiff if things feel too unsettled out there (high curbing, uneven surface, etc.)
setting #4 for me, on all 4 corners. If your roads are a little more on the bumpy side where you are then go with a higher setting. You didn't say if you lowered your car, but I would assume you did. Getting some more negative camber also factors in to the whole ride experience. GL and have fun driving your cayman.
