Put a hole in CS trans...
ON PURPOSE
Thought I'd share why.
We recently outfitted member 3 lions '07 CS with dual transmission coolers. The Cayman transmissions have been known to run very warm under continuous lapping track conditions. With reliability of 3 lions CS being of highest priority, we set off to develop a solution.
This dual transmission cooler system uses two Setrab fluid coolers to do the trick. A center console mounted switch runs the pump that pulls fluid from the rear of the case and supplies cooled fluid to the ring and pinion at the front.
To perform this modification, one has to be willing to put a hole in bottom of their transmission case. The rear cover is removed from the car and modified.
I would not recommend this for a street car, but for a consistent track schedule I would strongly consider it. As I said, there is a center console mounted switch so you can turn it on for track days and turn it off for the street or when not needed.
Currently we do not offer this system for purchase or installation outside of our Southern California facility. This system was developed for manual transmissions on the 987.1 models.
ON PURPOSE
