Perhaps someone can advice..
I have a 2006 Cayman S with about 13,000 miles. I have done about 7 track days and since the last one I note that the brakes give a catch and release sensation when coming to a stop. I notice this more a low speed. Any ideas what may cause this? Is that something related to the pads, maybe they need to be replaced even though they still have some meat? I have a totally stock set up but use ATE superblue. Never had this problem befpre. I am tempted to replace pads with a friend but I was wondering if this is the solution to the problem.
Thanks
7 track days on street brakes is a lot. Your pads are getting down there, no doubt. If it is pad deposits from getting street pads too hot, I'd suggest removing the tires and windexing the rotors on both sides. Remove the wheels, clean the rotors off with Windex and paper towels or disposable rags and see if it helps. While you're doing that, look for cracking around the holes in the rotors. Also look for non-flat surface to the rotors. Some rotors wear more in the middle than on the edges. The pad forms to this shape. It doesn't hurt anything, but it can cause that sort of sticky pedal feeling during very light braking that you're describing.
Craig is right about buying a good set of track pads for the DEs. They're better for the rotors and the street pads last a lot longer. Your street pads will love it. You are doing enough track schools to warrant a good set of track pads. Pagid Yellows are made for endurance racing and last forever. They don't wreck your rotors. They don't have great initial bite, just press down a little harder until they warm up. They'll stop you. You'll save your street pads. Porsche brakes are among the easiest pads to change. Very simple. I'm sure there's an article on this site. Buy a nice little floor jack. Harbor Freight has an aluminum one that's very reasonably priced...nice and light for packing for the track.
When you change pads, do the Windex trick as well. Some street compounds don't mix well with other street compounds. Some track compounds don't mix with other track compounds. I just play it safe and clean the rotors each pad change.
Here's what can happen if you don't clean the rotors with the wrong combination of pads... The deposit from one compound mixes with the deposit from the next pad material and forms a tar-like substance that sticks on the rotors. You get on the track and heat the brakes up and they shudder like crazy. You'd swear you had severely warped rotors.
Make sure and break new pads in carefully, especially with used rotors. If your rotor surface is uneven, new pads will only contact the high spots of the rotors until they are broken in. You do not want to brake hard until the pad surface matches the rotor surface. This causes hot spots and burning of the rotors and pads at the high spots. I drive generally at least 200 miles to the tracks I frequent. I change my pads before I go and drive with a mind towards managing the brakes as I drive. Eventually, they start to feel firm and I use progressively more pressure on them. First session, I go easy on new brakes. By second session, they're ready.
It's a good idea to mark the position of each pad's position on the car...both the street pads and the track pads. This way, you replace them in the same spot and the contour of each rotor surface will more closely match the pad. If you do this, the break-in will not be needed each pad change...only with new brakes.
Welcome to track world...Weird science.
:cheers:
