It's not a big deal but it does rattle a little. I played around with the wind deflector a little but still a slight rattle. Any fixes or suggestions? Or do I just have to live with it?
I had the same problem. It drove me nuts. I ended up putting a few small 3m felt pads around the edges of the wind deflector.
Haven't had any rattles since and it seems to be holding up well.
The ones that I used were similar to this but in black. You can get these anywhere. If you cant find the size you need then you can always cut it to the size you want.
Amazon.com: 3M Scotch 768ES Self-Stick Floor Care Pads 1-Inch Beige, 6-Pack: Home Improvement
A cheap and easy fix.
Hope this helps
On the edges? Where exactly?
Yea. I just took off the wind deflector and placed a few small pieces on the edges on the side and the bottom where it connects to the roll bar.
So the wind deflector is rocking? I haven't tried to figure out what the problem was, just noticed it. I'll try your idea. Thanks!
