Got it ... I'm strongly suspecting that the CANBUS dash relay click issue is causing the interference ... or at least the additional noise over and above what the SPP has by default.
Unfortunately it did not. Waiting for my connector adaptor to come in to try a few different things.
TBH, I am not an electronic & software expert but here is another shot of my Erisin chat message last month:Oh yeah looks like they got the orientation all wrong.
Hm… so they’re saying to short CAN low to ground? This is definitely starting to get over my head, but is it okay to even short CAN low to ground? My googling is saying no, and that while it’s unlikely to cause damage, it may cause faults.
I missed your question Zoomby_U. I chat with them through Aliexpress' Erisin Official Store. We also have communicated through email: [email protected]. The new quad lock wire harness adapter was sent later after I complained about relay switch tick noise & brake pilot light flashing. I have not installed yet and waiting for their response as it looks like they cut the wrong wire (speaker wire) instead of the Canbus L.Thanks for the updates gents ... it looks like I had the Canbus issue as well ie. relay click and parking brake light going on and off.
@anekdotos,Yes splicing in the RCA's did fix the volume issue and I thought about getting the attenuators but it's more trouble than it's worth TBH. I actually just soldered the wires back on the harness to put it back to OEM.
@Cayman Ed, how have you been getting a hold of Erisin? I've used their website to leave messages and sent emails to [email protected] but haven't heard back in 2 days. For some reason mine did not come with a harness ... so I guess if they sent me one, it would fix the Canbus issue at least. Then I could splice that harness and add 12db attenuators which should fix the problems.
Yeah - no go. The only connector that when removed completely stopped the noise (and any sound for that matter) was the blue connector in the quadlock. If you look at the pinout in my previous post, that has the "Amp On" pin. So, turning the ASK amp off stops the noise and all audio for me (not surprising).did you try unplugging the fakra connector to see if that helps
boot.img
file and now I'm bootlooping... and for whatever reason I can't get into recovery anymore (wont read USB Drive). Oh well, I'll keep poking and try to recover. If you could send me the FW files that'd be much appreciated!I experienced app looping after it has boot up when I tried the first solution/instruction of Erisin to turn off Canbus in Factory Setting and turn it on all in the effort to solve the relay clicking noise/brake pilot lamp flashing. Boot up was good except for app looping & radio station randomly changing. They sent me a firmware that I uploaded via USB port and solved the app looping. I still have the FW files but you can reach out to Erisin too if they have other solutions.
boot.img
(or you could pull it from an update file) and all was good. If I figure out the sequence of events Ill make sure to document it.Yeah I tried. The canbus high is required to turn the unit on / off. I tried to apply 12V to the wake pin as well on my bench supply and that wouldn’t turn it on either. So it seems it’s tied to the canbus high.
Yeah it's a bit annoying. I actually ordered a USBtin (USB <-> CANBUS) debugger to try to power it up on the bench and maybe add custom CAN commands etc. The static is annoying to me too - I'm receiving my harness adapter tomorrow and have a cheap DC power filter that I'll try... I'm committed to figuring this out.Thanks ... I tried the same on the bench and couldn't get it to fire up ... so I figured it needed the CANBUS to power onSo frustrating as it's the perfect unit but don't think I can live with the static
These are REALLY outstanding.. I'll have to post a picture of the Boxster one on the inexpensive Chinese Android for the 987/997 series cars. VERY nice!In other news, I got my hands on the original PCM31 software and managed to pull out the original bootscreens (i.e. Porsche Crest and Vehicle Silhouettes). You can get the originals and upscaled images here: PCM3_BOOTSCREENS - Google Drive
