We just restocked on our top selling wheel spacers and lug studs!
Widen your track for better traction and cornering, or to provide more clearance for wider tires, or to just make your car look better with our wheels spacers!
Our wheel spacers are available with either extended wheel bolts, or with Schnell Autosports' lug stud conversion kit for proper and safe installation.
Both options include countersunk rotor screws for securing the 7mm rotors to the hub.
Wheel spacer installation writeup: Schnell Autosports - European OEM/Aftermarket Parts + Racing: Wheel Spacer Installation
To place an order please give us a call at 1888-978-9899 or visit our website.
If you have any further questions, feel free to ask us on our contact page!
*Prices do not include shipping or any applicable taxes.
Discussion Starter #2
Schnell Autosports 7/15 Hubcentric Spacer Set!
Widen your track for better traction and cornering, or to provide more clearance for wider tires, or to just make your car look better!
Wheel spacers are available with either extended wheel bolts, or with Schnell Autosports' lug stud conversion kit for proper and safe installation.
If you're tired of the juggling act of holding your wheel up to keep it from falling straight down while taking off that last bolt, or holding your wheel up and trying to keep the holes aligned while you put in the first bolt, we have the solution for you.
Schnell Autosports offers a lug stud conversion kit, which converts your stock lug hole/lug bolt setup to a more familiar (and easier to deal with) lug stud/lug nut setup. Our conversion studs also feature an unthreaded portion at the end of the stud, to allow you to easily guide your wheel and lugnuts on without risk of cross-threading or damaging the threads on the stud.
Schnell Autosports Lug Stud Conversion Kit
Find out more information here.
Discussion Starter #4
We've just stocked more of our popular wheel spacer sets! Place an order today!
One set (two 7mm spacers and two 15mm spacers) of high quality CNC machined hubcentric wheel spacers for your car.
Other wheel spacer options here.
Installation is easy! writeup: Schnell Autosports - European OEM/Aftermarket Parts + Racing: Wheel Spacer Installation
