1 - 9 of 9 Posts
Super Moderator
After getting wider wheels and widening the track a little, I'm noticing that the rear part of the rear fender edge (which is part of the rear bumper) is getting really torn up - lots of stone chips, dirt, scratches, etc. in the paint and soft plastic.
After patching up the chips (just going to do this with some touch-up paint and some wet sanding), I was thinking about DIY'ing by placing a small strip of Xpel film over the fender edge, but I'm concerned about the job not looking too good. Anyone else have any alternative suggestions/solutions? The part of the fender edge that is made of the steel bodywork appears to be holding up well.
Super Moderator
Not sure. I'm here in Torrance, near Redondo Beach in the SoCal area. Lemme look up Premiere and see.
Edit: Aha, I see they have a facility in Orange, which is just a short drive. I think I'll touch up the defects myself and then just take the car over there to get a bit of film applied. Thanks, Pete.
If they are close by, you can head over and document their shop for us. One of the benefits of being a sponsor on here, right? ;)
Super Moderator
I definitely will. Just need to find time to make an appointment. :)
Same problem here, so I am interested in what DIY solutions have worked. I thought about buying replacement rock guards (or some material that is clear and a little stiffer than clear bra) and cutting out strips to cover these areas. The job needs to look reasonable and not perfect. I will wait until spring to paint the chips and do the fix given the weather here lately.
Venture Shield can sell you a sheet of extra thick film about the same size as a sheet of paper. Cut it and do it yourself.
Thanks for the tip, I'm finding this to be the case with street driving. :(
1 - 9 of 9 Posts
