1 - 13 of 13 Posts
My beloved 07 CS. (161K Miles) had an AOS failure at 80+ mph on the highway..(apologies to those 10-15 cars behind me who were plastered by my smoke and oily mist)
Car gave me 2 "oil pressure low" warnings an hour before the failure..
I checked the oil and oil level was good.. Warnings went away.. but an intermittent loud screech returned..
Just before the full blow up, the screech returned
Car lost 1 Qt of oil (from what I can tell)
I have procured a new AOS from dealer but am waiting on a Breather hose to complete the job
DO NOT put this off.. get it done before it becomes a problem
Not a hard job even for an amateur like me, but all this paid could have been avoided.
Bummer. Hope you do not have too much trouble cleaning oil out of all the places its not supposed to be.
I am all done with the cleanup.. replaced air filter while I was at it.. MAY have to replace MAF but no codes while I was coasting..
oil was everywhere... any residue I can't get to will have to burn off on its own... Will replace spark plugs too but once I am sure the issue has been resolved
Just waiting on the crankcase breather hose to put everything back together
Desmotesta- You have one of the highest mileage M97 engines without a rebuild on P9. Any tips on how not to destroy your engine.
AOS, I had the same thing happen to me at a local autocross. I was a big attraction in the staging area as the fellow competitors thought I blew up my motor. There is a drag strip associated to the autocross track, so I made a few full gas runs to help clean out the oil from all the parts. Later that week, I had my shop install a Porsche MotorSports AOS. No issues after that with the AOS even running Hoosier A7's.
When talking to the install shop, they told me that the reason I oiled down my AOS was I had overfilled the oil sump, believing that I should have a full sump. Not so, according to LN, who made the deep 10 qt sump, I should have been running less than 1/2 the gauge or 2/3 qt less than max. I now run 2/3 of a qt low as per LN/Cantrell motorsports recommendations while using this sump with windage tray, even with the Porsche Motorsports AOS.
Welcome to the 'club' :(
Well I was driving my 06 CS MT & being pestered by a Jeep on a very twisty low speed road. Knowing that a sharp, near 270 degree, right uphill turn approached, I baited him a bit and let er rip! Hmmm he and the other 3 cars behind him disappeared! No, not from speed but from the mammoth cloud of smoke I produced. Coasted her into the quiky mart...could almost hear the sneering haha. Informed ahead of time thanks to P9, no panic. Put er all back together (inc plugs/coils/cats) and she ran ok but was giving me stumble about 5k and up. After having to buy a 5 point torx driver (tearing out some hair as I had 100's of bits/wrenchs/etc etc that wouldn't loose the damn MAF, using a mirror this I discovered) I then used the official MAF cleaning spray and voila! Never ran better. Just a heads up and good luck!
Discussion Starter #6
Can you elaborate on the official MAF cleaning spray?
Discussion Starter #7
I honestly dont know what to tell you..
I bought the car with 142K.. previous owner babied the car and never drove it hard (claimed), over rev reports 0 over revs in any zone
I change oil every 5K like he did.. I use Castrol 0w40. (he used M1 all its life)...
I have Soul Long tube headers, milted exhaust and a tune.. I drive it hard 90% of the time.. but I never rev past 6000-6200..never.. there is no point (on streets)
I have a couple of motorcycles and straight-line "speed" is not what I have the car for...
Apart from not redlining, I am flat out and Full throttle most of the time..
I HOPE it can make it too 200K.. and judging bye how things have been going (apart from AOS) I have no doubt that I can get there
Discussion Starter #8
Happy to share that my baby is back on the road
After hours of cleanup, replacing AOS, Crank case vent hose and a vacuum hose... I was finally able to crank her up
Cant tell you how much I was cringing, feared for metallic sounds from engine etc
It seems to be a happy ending for now..
hope many more miles to go... Hard work DOES pay off... I feel like I was beaten with a baseball bat, but it was SO worth it
Sorry for the delay...
"CRC 05110 Mass Air Flow Sensor Cleaner - 11 Wt Oz" for example. Auto store or A%azon.
Mine has been perfect, perhaps even peppier, after the AOS fog and subsequent plugs/paks/cat refresh. Glad to hear you're running again!
Discussion Starter #10
thank you..
Mine is hesitating on Full throttle. I did not change the MAF, didn't clean it yet either. Have no codes.. just hesitation
Discussion Starter #12
Update: MAF had oil residue on it.. Cleaned the MAF with CRC MAF cleaner and all is well now
OK, a simple question. I have a '14 CS with (just last weekend) 30k miles on it. Is there a recommendation for when to replace the AOS as part of some future maintenance to avoid a messy blow up (on-track or otherwise)?
1 - 13 of 13 Posts
