1 - 8 of 8 Posts
Schnell Autosports Porsche Parts and Services!
About that time your brake pads/rotors need to be replaced or you have an oil change coming up? If you're local, schedule your next brake or oil change service with us!
To schedule an appointment or for any general questions give us a call at (888) 978-9899 or email us at [email protected]
We also carry OEM and aftermarket Porsche parts! Pick up your order and save on shipping! Just select will call at check out.
Schnell Autosports | 1-888-978-9899 Toll Free
500
7th Street Unit J, Rancho Cucamonga, CA 91730
Discussion Starter #2
Doing an oil change on your 987/981 Boxster or Cayman?
Order (4) Mahle oil filters and save! Just select Schnell Super Saver Special in the options.
OEM Mahle Engine Oil Filter (OX 366D), 987/981 (09+)
If you're local, select will call at check out and save on shipping!
To place an order please give us a call at 1888-978-9899 or visit our website.
If you have any further questions, feel free to ask us on our contact page!
*Prices do not include shipping or any applicable taxes.
265498
981 Boxster/Cayman Brake Pad/Sensor Packages
Replacing your old brake pads? Save with our 981 brake pad and sensor packages!
Available in front and rear or both options for 981 Boxster and Cayman models.
Packages include OEM Textar brake pads and Sebro brake pad sensors.
265339
265340
9500 7th Street Unit J, Rancho Cucamonga, CA 91730
Discussion Starter #4
Storing your car for the winter? Keep your car battery properly maintained with CTEK's Multi US 7002 Battery Charger!
The CTEK Multi US 7002, with a thorough 8-step process for maintenance and charging, is well suited for year-round use with just about any vehichle. A special "Recond" made reconditions a drained battery after deep discharging, allowing the battery to recover more quickly and last longer. The CTEK MULTI US 7002 also functions as a power source, enabling in-place replacing of batteries, without lass of power to the vehicle electronics. In addition, the CTEK MULTI US 7002 is recommended for Optima Yellow Top Batteries.
Check it out here!
265540
265541
To place an order please give us a call at 1888-978-9899 or visit our website!
If you have any further questions, feel free to ask us on our contact page.
**Prices do not include shipping or any applicable taxes.
Schnell Autosports - 981/991 Braided Brake Lines
Improve the brake feel on your 981 Boxster/Cayman, or 991 911 with Schnell Autosports' braided brake lines!
Stock brake lines can actually bulge out slightly when you press your brake pedal hard, and that outwards movement translates to your calipers not squeezing your brake pads as hard as they can. Braided brake lines eliminate that sideways flexing, ensuring that you get as much braking power as you can. All of our braided brake lines also have an additional outer sleeve to protect the braided sleeve from abrasion.
(product page)
265701
Discussion Starter #6
When you use your brakes, your calipers squeeze your brake pads against the rotors, using friction to convert your kinetic energy into heat. That heat is ideally absorbed by your brake rotors, where that heat can then be dissipated.
That heat, however, doesn't want to just go to your rotors and pads; it wants to go anywhere that it can. If you're driving your car hard, or if something is wrong with your braking system, you'll find that your brakes are generating heat in excess of what your rotors can shed.
Excess heat causes things like brake rotor cracks, brake pad glazing, and brake fluid boiling, with the end result being a loss in braking performance, or even outright failure of your brakes.
One simple way to help keep that heat away from your calipers and brake lines is to replace your stock brake shims with our titanium brake shims.
It's no secret: titanium is a good insulator for heat, especially when compared to steel. Using titanium brake shims instead of steel means your brake pads will transmit less heat to your calipers, which in turn transmits less heat to your brake fluid. As your pads wear down from use, they allow more heat to be transmitted to anything in contact with them, which makes having a way of mitigating that heat with our titanium shims more important.
If you like to track your car, or just like to take your car for "spirited" drives, our titanium brake shims will help you to drive harder with less chance of your brakes fading, and will help make your braking system last longer.
Our titanium brake shims come in a set of 4
Please see product page for vehicle fitment.
Titanium Brake Shim Set - Front (981/991/997/987)
Titanium Brake Shim Set - Rear (987/981)
265782
265783
265809
265810
Schnell Autosports 981 Boxster/Cayman Brake Packages
Replacing your old brake pads or rotors? Save with our 981 brake packages!
Packages include Textar brake pads, Sebro rotors and brake pad sensors.
For pricing and information, please see the links below.
981 Boxster/Cayman Brake Rotor Package
265892
265893
Discussion Starter #8
Brake pads/rotors need to be replaced or you have an oil change coming up? If you're local, schedule your next brake or oil change service with us!
265498
1 - 8 of 8 Posts
