1 - 2 of 2 Posts
Banned
Need a full set of TPMS sensors for a new set of wheels, or to replace ones that you've damaged? Today's sale is for a full set of Huf TPMS sensors. The OEM TPMS sensors that Porsche uses are actually made by Huf, so you know that our set will work the exact same (just without that "Porsche Tax" price).
These sensors are 433 MHz. Please ensure your vehicle's TPMS sensors are the same frequency (you can call the dealership and give them your VIN to confirm).
Package contains the following:
(4) 433 MHz Huf TPMS sensors (valve stems not included).
Sale Price: $329.99
This sale is phone order only, and not listed on our website. If you are interested, please call us toll-free at 1-888-978-9899.
Sales prices do not include shipping and tax.
Banned
Discussion Starter #2
Today's sale is for our CNC machined hubcentric wheel spacers kits. Whether you're trying to widen your car's track for better performance, or just want to push the wheels out to make your car look more aggressive, our spacer packages are what you're looking for.
The spacers are hubcentric, and are in the correct 5x130 bolt pattern with 71.6 hub bore, and include countersunk rotor screws for the 7mm spacers. All packages also include either extended lug bolts (necessary when running spacers), or our lug stud conversion kit.
Spacer package 1 gets you 7mm spacers for the front and rear of your car, as well as the necessary extended lug bolts and rotor screws.
Spacer package 1 contains the following:
(4) 7mm hubcentric spacers
(20) extended lug bolts for 7mm spacers
(8) countersunk rotor screws
Spacer Package 1 Sale Price: $199
Spacer package 2 gets you 7mm spacers for the front, and 15mm spacers for the rear of your car, as well as the necessary extended lug bolts and rotor screws.
Spacer package 2 contains the following:
(2) 7mm hubcentric spacers
(2) 15mm hubcentric spacers
(10) extended lug bolts for 7mm spacers
(10) extended lug bolts for 15mm spacers
(4) countersunk rotor screws
Spacer Package 2 Sale Price: $216
For those of you tired of the juggling act needed to take off or put on your wheels using lug bolts, these next two packages are your solution. Instead of extended lug bolts, they come with conversion kits to go from lug bolts to the more familiar lug stud/lug nut combination. Our conversion lug studs feature an unthreaded portion at the end of the stud to help guide your wheel on without having to worry about any damage to the threads. As a bonus, the lug stud conversion set weighs less than the equivalent lug bolt set.
Spacer package 3 gets you the same set of 7mm spacers for the front and rear of your car that package 1 gives you, but replaces the extended lug bolts for our lug stud conversion kit, as well as lug nuts and rotor screws.
Spacer package 3 contains the following:
(20) conversion lug studs for 7mm spacers
(20) open ended lug nuts
Spacer Package 3 Sale Price: $234
Spacer package 4 gets you the same set of 7mm spacers for the front, 15mm spacers for the rear of your car that package 2 gives you, but replaces the extended lug bolts for our lug stud conversion kit, as well as lug nuts and rotor screws.
Spacer package 4 contains the following:
(10) conversion lug studs for 7mm spacers
(10) conversion lug studs for 15mm spacers
Spacer Package 4 Sale Price: $254
For those of you looking at buying either 7/15 kit (packages 2 or 4): please ensure that the addition of 15mm spacers on the rear of your car, in conjunction with your wheel and tire combination, has enough clearance to prevent rubbing of the tire against any part of the fender area (or you are willing to modify your car to prevent rubbing). Due to the wide variety in wheel styles and tire choices, we cannot guarantee if 15mm spacers in the rear are appropriate for your application, and we cannot accept returns on spacers once they have been mounted on the vehicle. If you are unsure, we suggest one of the 7mm kits instead.
Sale prices do not include shipping and tax.
1 - 2 of 2 Posts
