1 - 14 of 14 Posts
Hi Guys,
Just noticed the plastic on my speedo is a little scuffed up. Any suggestions on how I can make this problem go away?
Would it be possible to change just the plastic without changing the whole instrument cluster?
Thanks in advance...
If its actually a scratch use toothpaste and a toothbrush.
+1 on toothpaste, but I'd rub with a microfiber cloth like the one that come with prescription glasses.
DO NOT USE TOOTHPASTE OR A TOOTHBRUSH!
The abrasives in toothpaste are not milled in the same size or fashion as those in a dedicated polish. Toothpaste will have a scouring effet on the plastic and will most certainly remove any anti-glare coating on the surface. I don't have my car yet and I don't remember from the test drive (in Feb) if the gauges had the glare reduction coating on them. If it does then polishing will cause a weird looking spot where the coating is missing. If there is no coating then try the plexus or a good automotive paint polish like Menzerna Power Finish with a good microfiber towel to start.
Edit: You can usually tell if there is anti-glare film by fiewing the gauges off-axis and in direct light. If there is a greenish or purplish tinge to any reflected light then its a safe bet it's there.
I thought I noticed a purplish tone to one of my gauges yesterday when the sun shined on it at a particular angle. Maybe that was why.
Then off to the dealer.......it's a brand new car, nothing out of pocket.
This is what separates a truly professional detailer from a wash and wax guy. We have to know ALL the ins and outs. The best products from each brand and the best process for each type of paint. I called out a well known (Robb Report top 10 listed) detailer on autopia for removing a "purplish film" from a customer's BMW M3 nav screen. A few days later, he deleted every picture from his post and it died quietly.
I guess the lesson is that you always have something to learn. I've made mistakes too.
Plexus is great for cleaning I use it by the truckload cleaning the covers on my boat.
But it will not remove a scratch. You would be polishing into the next millennium.
The OP was about a scratch, if you are going to remove a scratch you are also going to lose any protective coating. You have to pay your money and take your chances. If it doesn't work you have no choice but get new plastic covers.
Discussion Starter #11
hey guys sorry for the lack of replies... was in a tropical hideaway sulking over my problem :) Back to reality now. Will be be looking for Meguiar's PlastX tomorrow to see if it works. If not probably will try the Icre Creme scratch remover. Review here
Just curious if the plastX resolved the issue..? Thanks for responding..
Discussion Starter #14
Yup 80% resolved. Bulk of the scratches came off. Thank goodness! It doesn't work that well on TechNoWind V1 though...
1 - 14 of 14 Posts
