Sorry for any confusion. I looked closer at my 991 anchor and as you say it's a 12 pt internal. All of my bits are 6pt.It's actually an internal flats bolt, not a hex, requiring a bit. I just need the size.
Yep, mine too...Sorry for any confusion. I looked closer at my 991 anchor and as you say it's a 12 pt internal. All of my bits are 6pt.
Thanks, I'll read it. I'm mostly concerned about trim removal. Once I see bolts, I can deal with bolts, but Porsche trim... It's often non-trivial, and the tabs break easilyI didn’t totally remove mine but the PSE write up I did should help you get to them. I would think it’s a pretty straight forward job once in there. If you find out what the seat belt anchor bolt size, post back here if you don’t mind.
http://www.planet-9.com/reviews/cayman-performance-modifications/p593-porsche-sport-exhaust.html
It has been my experience that you simply have to 'look' at some Porsche trim and it breaks... almost like it knew you were going to touch it! :hilarious:Thanks, I'll read it. I'm mostly concerned about trim removal. Once I see bolts, I can deal with bolts, but Porsche trim... It's often non-trivial, and the tabs break easily![]()
I was too, but it's honestly built pretty rugged since it has to be removed periodically to reach the engine and air filters. All parts have nice insulators and robust clips. It feels pretty wrong sometimes the way it comes off (I shouldn't be pulling this like this)Thanks, I'll read it. I'm mostly concerned about trim removal. Once I see bolts, I can deal with bolts, but Porsche trim... It's often non-trivial, and the tabs break easily![]()
Great, thanks! I guess i'm getting new seat belts then!I was too, but it's honestly built pretty rugged since it has to be removed periodically to reach the engine and air filters. All parts have nice insulators and robust clips. It feels pretty wrong sometimes the way it comes off (I shouldn't be pulling this like this)but it was totally fine. The biggest thing is know which way the clips come OUT of the slots so you aren't pulling sideways and break them. Look up Voyager6 on here for a great PDF of pulling out all the interior trim to get to the engine topside. Then it's just a few more to get to the seat belts. By the time you get that far in, you will be confident in the process.
Cool, let us know how it goes and post some pics. I've considered this but was not able to source OE seat belts. Even one s from Suncoast are not, I don't believe.Great, thanks! I guess i'm getting new seat belts then!
Nice. Those are the GTS seat belts, look. Should look great!I'm going with this. They just change the belt in the factory hardware that you send to them: http://www.planet-9.com/718-chat/217105-coolest-seat-belts-youll-see-today.html
It exactly matches my car color schema!
Did you ever get these installed?? If so let’s see some pics. And do you recall the seat belt bolt size at the floor? Triple twelve M??I'm going with this. They just change the belt in the factory hardware that you send to them: http://www.planet-9.com/718-chat/217105-coolest-seat-belts-youll-see-today.html
