1 - 3 of 3 Posts
Hello,
I have removed the Air Conditioning on my car and now I need to replace the serpentine belt. Can someone tells me what length I need (Without Air Conditioning and with an under drive pulley)
Thanks,
Standard length belt for the 987.1 is Gates P/N: k060832 (I don't know if the base model use the same P/N)
For an underdrive crankshaft pulley and A/C, many recommend using a belt about 10mm shorter than stock. I used Gates K060827 which their site lists as 11mm shorter.
For an underdrive and NO A/C, if you can find the actual Continental or other brand P/N you can go to www.gates.com and search for an interchange listing.
If the search is successful this will give you the Gates P/N and its length. At that point you can buy the Gates, or probably convert to your favorite brand. Whatever belt you choose be sure to record the brand and P/N for future reference.
1 - 3 of 3 Posts
