Our 986 Spec Boxster Race Exhaust is now available!
FITMENT: All Porsche 986 Boxster vehicles with manual transmission (1997-2004)
WEIGHT SAVINGS: 24.8 lbs / 11.2 kg less than factory exhaust components (14.7 lbs vs 39.5 lbs)
DEVELOPMENT: Several Spec racing teams and shops including our development partner, Brandywine Motorwerks, have been seeking an exhaust solution that is durable enough for racing use as existing systems on the market and DIY solutions have been known to fail. We set out to build the most durable system possible while being cost effective and minding weight. A lack of resonance damping in a 986 exhaust system for competition use can cause metal fatigue in the factory headers, resulting in cracking. We crafted bespoke, adjustable brackets to mount the exhaust to the transmission to match movement of the drivetrain to the exhaust opposed to hard mounting to the body. Silicone dampers are also included as part of the brackets to help absorb vibrations. Clamps are not welded to the piping to prevent fatigue and provide easy / efficient replacement – the only welds in the entire system are in the flanges to the headers and every weld is back purged for maximum weld strength and durability. The brackets and tailpipes are adjustable for the best possible fitment. The tailpipes are easily replaced in the event of collision damage. 2″ straight piping keeps exhaust velocity high and weight down. Sound attenuating components like resonators are decidedly absent to reduce weight and complexity as PCA Club Races are not hosted on sound limited days. Should decibel limits be considered for other competition series or HPDE events on sound restricted tracks, alternative solutions can be used. The end result is a race bred system that will hold up to the stresses of racing and last until you podium – and beyond.
CONSTRUCTION: Each system is made in-house by our fabrication team from mandrel bent .065″ wall, 2″ diameter T304L stainless steel tubing and laser cut brackets. All welds are back purged for increased longevity under the most extreme conditions. Each exhaust component is then rigorously quality-checked, tested in a fixture to ensure perfect fitment, and then foam packed to ensure it arrives in perfect condition. New high grade hardware is included.
LIFETIME WARRANTY: We warranty this system in full both the street and track under our Lifetime Warranty! Our team will quickly work with you to resolve any issues or answer any questions that you may have. The only exclusion is damage to the system caused by variables outside of our control, such as getting a love tap in the rear or embracing a barrier.
CHECK ENGINE LIGHT?:
This race exhaust will trigger a check engine light due to removal of factory catalytic converters and deletion of the secondary o2 sensors. If this is bothersome, some race shops servicing SPB cars recommend turning off the CEL via removal of the CEL bulb.
MSRP: $1,295
AVAILABLE TO ORDER NOW!
It's been a pleasure working with the community and we look forward to quickly getting you your exhaust components or helping in any way we can by answering any questions. Don't hesitate to reach out to us!
Contact us any time with questions, customization requests, to order, or find your nearest SOUL dealer / installer
Email: [email protected]
Phone: 855-486-1400
IG: @soulperformanceproducts or John Gaydos Cell: 484 883 6197 for after hours support
