1 - 8 of 8 Posts
Sport wheel paddles on pdk 981 CS
Hello every one,
has anybody info on why or if the up-shift paddle on the PDK sport steering wheek klicks before the electronically up-shifting??
Not occured on downshifting lever/paddle, which moves freely ( no small resistance I mean)
It seems like the resistance you feel while you pull or push the power windows switch to FULLY lift or lower the windows.
thanks.
I need to say that I have no problem on up or down shifting the gears.
Christ
PCA Member and DE Instructor
It is a switch. Sometimes the activation can be harder than a switch of the same manufacturing batch - yet still be in the tolerance band (force needed). But you should not be able to hear a click prior to the electronic shift. It should be instantaneous, at the same time.
Hi and thanx for replying
Its not actually a click, its like a resistance like the power windows switch when you press them to have all the way up or down the window glass.
After several drives, in all the different modes, I:
1. don't hear any audible clicks on upshift/downshift
2. feel a consistent resistance to the paddle pulls (no type of resistance change like the dual-mode window button you describe)
This is on 2014 CS w/PDK and Sport Chrono via Sport Steering Wheel.
Can't re-produce it, sorry. Wow, sound like a dealer at service time! LOL!
thanx for your reply
i agree on the not audible clicks
ans yes i feel a resistance pulling but not all the way , in the middle of pulling i feel the resistance and then ...thats its next gear in in
p.s. may i ask you if your navigation 3D shows ALWAYS 3D buildings, terrains, POI or only on map data from countries that have up dated Porsche/Navigon ?
thanx again, Christ
thanx again, Christ
Definitely doesn't always show 3D! Wondering about that myself.
In downtown/Wilshire/B.Hills areas of Los Angeles I can see the 3D no problem. Here where there are still 10 story buildings: nothing. At least yet....
Re: Sport wheel paddles on pdk 981 CS
I have buttons, and sometimes a button upshift has a slight lag. Maybe when cold...
Reactions: CHRIST
1 - 8 of 8 Posts
