Hi all, I was reviewing the SRP install instruction in the Articles section. One of the last steps of the SRP install calls for disconnecting the coolant sensor (if you're using the older software).
I assume the newer software flash worksaround the need to disconnect the sensor. Though, I'm curious what's the "connection" between having the SRP installed and the coolant sensor? Any thoughts?
Thanks!
Thanks!
