1 - 8 of 8 Posts
Unless different in your country, turning it off is a setting (here anyway) that stays set when car is next started. I've heard some countries have different requirements for that to reset I believe?
Changing these settings can only be done with a PIWIS 2. Without this you will have to turn off each time in the car.
As Georgeair stated, depending upon your country, the switch setting may be retained. I turned mine off years ago and haven't touched it since.
or just put in a racing battery. As soon as I put in a racing battery the car always thinks it is low and automatically disables the start stop.
Install the T-Design memory module
t-design9.com
Very easy to install and works brilliantly
Hello
No need for the original diagnostic or messing with the battery etc.
You just need a good diagnostic kit that give you this option. My car imported from England with start stop always resetting. It only took few minutes .
I can tell you the diagnostic kit brand in few weeks that i will go for the service. If its of any help, usually diagnostic kits that allow you to activate the "dyno rolling mode" should have the start stop option also.
1 - 8 of 8 Posts
