Hello folks -
I get a load static noice, almost ear piercing, that lasts for a few seconds when I open my driver side door
its intermittent and the radio will not work afterwards for a few hours.
Any thoughts and help would be appreciated.
2006 Cayman S - all stock.
My first guess would be that you have a short or other connection problem in the cable(s) that go into the door. If you are able, I would remove the door card and see what's going on in there. Pay special attention to the cable where it goes from the door edge through to the rest of the body.
Good luck, and let us know what you find.
The static sound comes blaring through the speakers -
this happens with the radio shut off. Then causes the radio to not work for a day or two.
Almost like a capacitor discharging - amp maybe?
was hoping this was a common problem so I could find a cure for the mystery.
I'm having the exact same problem. When I have time this week I'm going to pull the radio out and check the connections behind it. Failing that it may be an amp problem as I've seen companies in Europe offering a repair service for the Porsche Bose amp.
Thread I created already
