Hi gang - Still trying to trace an oil leak for the past 6 months, and I think I’m getting closer to narrowing it down but could use some help.
After driving and returning home, usually there’s about a 1/4 cup of oil on the floor directly underneath the front driver’s side (LEFT) of the engine. I've definitively determined that it isn't from an old steering fluid reservoir overflow mess and is indeed engine oil.
The top of the engine is bone dry and you can’t see anything from the top. However, you can see some sweating if you look from behind the seats as in the first two photos - not mention at the top of that hard line that goes to the large hose that exits to the floor. The next shot is taken from underneath, that I took months ago where things are a lot messier.
Are there two problems here
where there’s a small leak higher up and a major leak below it all? My guess is that it’s all coming from just one place — but there’s no smoking gun and anything up top doesn’t seem like it’s been catastrophically leaking to cause such a great mess below. This has clearly been chronic issue, as the plastic underbody is caked with oil in that location; worried it was a major seal that a previous owner ignored. Thanks!
FROM BEHIND THE DRIVER'S SEAT
FROM UNDER THE CAR:
FROM UNDER THE CAR:
