1 - 10 of 10 Posts
Local group of car enthusiasts organized a dyno day. Unfortunately, they couldn't easily get access to the engine to read rpms. They tried reading from the power outlet, but it read 2k when I was actually at 3k, so the torque figures are way off. Did first two pulls in 5th and third in 4th.
Discussion Starter #2
Approx 1200 miles on odometer. 74.38 deg F, 29.90 in-Hg, humidity 27%, SAE 0.98
That torque is absolutely incredible! The factory is rating the Cayman GTS engine at 280 ft/lbs.
Either your engine is highly modified, or Porsche is severely under-rating these "official" specs.
Either way, it's all good!
Discussion Starter #4
Torque is computed from the rpms and they couldn't get a good read of the rpms
Here's a pic of my car strapped down
Sorry but that dyno is useless since it was not set up properly plus.... No way you did 170mph on that dyno, and it should have been done in 3rd or 4th....definitely not 5th. Beautiful GTS though, congrats
Top speed is over 175 mph. I don't see why that number is the one you take issue with. :) He said he did a run in 5th gear. Would 5th get you to 170?
Discussion Starter #8
5th is closest to 1:1 being 0.95. Ignoring air resistance, it can theoretically hit 172 MPH. As noted, the 3rd run was done in 4th.
Thanks for posting.
There is something basically wrong though with the 4th gear run. It shows a completely different power profile.
I'm not sure the dyno was set up and calibrated correctly. It looks like its about 20HP too high from a calibrated number.
Cheers
1 - 10 of 10 Posts
