81 - 98 of 98 Posts
Sounds great! If I may ask, what is the tire thickness with a 275 (in inches)? Did you change wheels for aesthetics or to fit wider track?
As I know the standard car has 265/35 rear wheels with a tire width of approx 8.5inches. The reason I ask is that my C-class has 265 rear with tire width measured at 11 inches.
I don't know what you mean by "thickness" but 265/25.4 = 10.433" which is the width and 10.433 x .35 = 3.65" which is the sidewall height. If your C class and your Porsche both have 265 tires, they are both 10.433" wide (within an 1/8").
Dear 981 owners,
In order to better help us help you, I've put together a brief survey that I would like each 981 owner to answer. We will compile the results and hopefully come up with some offerings that will benefit our members. Please take a few moments to reply to this survey.
Sincerely,
Question 1: What modifications have you made to your 981 in the last 12 months?
Expel ultimate 85 % of the car
Ceramic Pro Gold Package, ceramic pro for two sets of wheels
OZ 19" track tires, Bridgestone RE 71 track tires
Zunsport front grills
LED lights for clear side markers
Question 2: What specific brands/parts have you purchased to make these modifications? (Example: XYZ Company Wheels or ABC Company ECU Tuning)
Expel for wrap
Ceramic Pro for coating
Tire Rack for Wheels and tires
Zunsport
OEM for side markers
Question 3: How much did you spend making these modifications? (Estimates are fine, for example "About $2000", etc.)
Expel about $ 2,500
Ceramic Pro for car and wheels about $ 2,800
wheels and tires about $ 3,400
Zunsport Front Grills about $ 300
OEM side markers about $ 60
Question 4: Can you briefly explain why you bought each item you listed? (Example: "Was on Sale", "I considered it the best in the market", etc.)
Expel expensive car that I plan on keeping along time to protect paint finish
Ceramic Pro same reason
Wheels and tires for track days
Zunsport front grills to protect radiators from crap damaging them
OEM side markers cause they look much better
I appreciate any and all responses to these questions as they will help us make Planet-9 an even better place to be!
Q1: What mods have you made to your 981 in the last 12 months?
IPD Plenum w/ 82mm GT3 TB - Shipped
Borla Catback Exhaust - Installed
Borla Rear Diffuser - Installed
DEPO Smoked Side Markers - Installed
Q2: What specific brands/parts have you purchased to make these modifications?
See Q1
Q3: How much did you spend making these modifications?
IPD Plenum w/ 82mm GT3 TB - $1098.86
Borla Catback Exhaust - $1529.99 + S&H
Borla Rear Diffuser - $449.99
DEPO Smoked Side Markers - $40.95 + S&H
Q4: Can you briefly explain why you bought each item you listed?
IPD Plenum w/ 82mm GT3 TB - Should improve performance.
Borla Catback Exhaust - Wanted to hear the flat 6 roar and Borla delivers.
Borla Rear Diffuser - Should improve aero.
DEPO Smoked Side Markers - Because I wanna look cool.
***Haven't ordered yet, but what are your thoughts on the FVD Genius Flash Tool? I have the old B30 ROM on my base Boxster, and Cobb won't support it unless I upgrade to the C30 ROM at the dealership (which has been a back and forth headache that I don't want to battle anymore). Thank you for your advice!
15128998_10105766377724718_4851199365539004315_o.jpg 15068473_10105766377774618_1334248643200820079_o.jpg 15122981_10105766377789588_1324464543065061933_o.jpg odw3OcT.jpg DR3MpVR.jpg
K&N air filters
Clear LED side markers
IPD Plenum, GT3 Throttle Body, Cobb Accessport tune, Borla Catback, Borla Rear Diffuser
BBi street cup suspension w JRZ RS1 coilovers, Tarett Swaybar Endlinks, BBi Toesteer kit, BBi Thrust Arm kit
BBi Rollbar
Cobra Suzuka Pro GT seat w Schroth 6-pt harness
Endless brake pads w Brembo brake fluid flush
ECS Wheel spacers
Michelin Super Sports
Torco 5w-40 oil
Xpel front half (nose, a-pillar, front 6' roof, doors) from Protective Film Solutions
Just purchased the car in January 2017 but since then:
Porsche GTS black exhaust tips
Porsche clear side marker lights
Porsche front trunk liner
Das Schild hood protector
Covercraft UVS100 windshield shade
See above
Porsche GTS black exhaust tips - $540 from local Porsche dealer
Porsche clear side marker lights - $65 from Suncoast
Porsche front trunk liner - $165 from Suncoast
Das Schild hood protector - $199 from Lid Liner
Covercraft windshield shade - $59 from Covercraft
Porsche GTS black exhaust tips - aesthetics
Porsche clear side marker lights - aesthetics
Porsche front trunk liner - protect front trunk
Das Schild hood protector - protect front trunk from spills, etc. and aesthetics
Covercraft windshield shade - protect interior and keep it cooler
K&N air filters
BBi Rollbar
ECS Wheel spacers
Torco 5w-40 oil
did you do an OTS Cobb tune or protune? If protune was it done on a dyno or Cobb Access Port data log? Did you have your engine performance mods installed at same time or in stages? Any performance feedback you can provide would be great. I just installed the IPD plenum & 82mm throttle body on my 16" CGTS (manual trans. & Porsche sport exhaust). Definitely feel a stronger pull above 4000 rpm. I spoke with Fabspeed regarding a tune and they recommended a Cobb protune via. access port data log. They claim I should see another 15-20 rwhp. Thanks!!
- Camber plates
- X73 F/R sway bars
- Rennline 991/981 Clubsport Camber Plates
- Porsche X73 sway bars
- Camber plates, istallation and alignment $950
- X73 sway bars, bushings, installation, alignment $900
Camber plates were very well made from aircraft grade aluminum, fitment was perfect, max camber is now -2.75.
Front and rear X73 sway bar keep the "Porsche handling balance", they really reduced leaning, diving, and squatting. IMHO, on a PASM equipped car it helps the car handle as good as X73 equipped car, if not better.
I just used the OTS Stage 1 tune. I think Stage 2 is if you upgrade to headers, which I have not. I did not pay the extra for the dyno test, but the car fells have a little more torque. I was not expecting too much gain - maybe 325 to 350hp. I emailed Cobb and they recommended a pro-tune via the access port for best results. Maybe in the future I will. I spent a lot last year between the various mods I did. Now I am spending my funds on track days to get to know the car better. I did the mods all at once, since I had Bbi Autosports do them. I know it is better to do one mod at a time and spend time getting to know the changes, but that would have taken a lot of time and cost more money.
Right at a year ago I installed a PCM with nav and sat radio in my CGTS.
Today I installed the updated inside mirror fromy Suncoast.
Next up, a GTS Sport Design steering wheel w/ multi-function buttons.
Zunsport, PSE, Rear Diffuser and Side air scoops
Except PSE, rest were cosmetic. So, none
~$5K including install
Few of nice to have mods. PSE - best OEM option
.Question 1: What modifications have you made to your 981 in the last 12 months?
F/R trunk liners
Porsche rubber floor mats
NavTV b/u camera
Fabspeed sport headers
PSE cat back
AWE Tuning Foilers
Cobb accessport + PDK tune
Window tint (bronze)
Escort Max2
Waylens Horizon
See above:
$~7400
Question 4: Can you briefly explain why you bought each item.
Liners/mats - carpet protection
NAVTV - rear view for reverse
Grilles - keep debris out
Headers - great deal 2nd hand but brand new
PSE - valved exhaust, used/ right price to test drone
Foilers - remove wind buffeting
Cobb - great sale price
Tint - reduce sun glare inside (beige)
Escort - "safety"
Waylens - dash cam features
This has been a very enjoyable thread to read. I just picked up a 2015 981 Cayman S today. It is nicely optioned and the PO also added clear film and window tinting as well as the clear side markers. It is practically new with 6,800mi. Strangely, it has Sport Chrono but not PSE, so I'll get to an exhaust first. Then things like the Zunsport grills, GT4 style side intake blades. Also, a Cobb Accessport and a pro tune will be coming. I've had a 2017 Macan GTS since March and I have to say, the turbos definitely offer a much different experience.
I've owned my CGTS for a little over three years, and made a lot of minor mods in the first year. However in the last year:
1) Black anodized dash trim
2) Aluminum pedals
1) Porsche (Suncoast)
2) Porsche (Suncoast)
1) $1065
2) $440
I didn't order these options with the car because I was maxed' out with the cost of other "more practical" options. Finally got around to doing it after not finding an acceptable more cost effective alternative.
1. Mods in 2017:
I have done very little this year (but lots of small mods in 2014-2016). This year,
-- I replaced the rotors with Girodisc direct replacement slotted rotors.
-- Upgraded the sway bars/drop links to TPC Racing adjustable sway bars/drop links.
2. Brands/parts:
-- Girodisc rotors from Competition Motorsport.
-- Adjustable sway bars and drop links from TPC Racing
3. Prices:
-- Rotors: $1,936 (normally $1,100 per axle, but all brake products were on-sale for 12% off).
-- Sway Bars/Drop Links: $1,790
4. Why?
-- Rotors: I track my 981 Cayman S 7-8 times per year, so I go through a lot of rotors. Slotted rotors are best for track applications because, among other things, you get a lot less cracking than cross-drilled rotors (like the OEM ones that came with the car), so they last longer. I have been looking for someone that sells slotted direct-replacement rotors for the 981 for years, but I only found "big brake kits" that required replacing the calipers too. Having used the OEM calipers on the track a lot, I know they are sufficiently awesome, so I do not want to replace them. But the OEM rotors crack all to hell when using them on the track due to the constant heat-cycling. Well, I finally found out that Girodisc makes direct-replacement rotors for the 981.
-- Sway Bars: Again, I track my 981, so the TPC Adjustable sway bars and drop links give me a motorsport solution to improve handling and my confidence on the track.
[] What modifications have you made to your 981 in the last 12 months?
-Fabspeed Protune/ Cobb AP
-X73 Sport Suspension
-FVD Brombacher Sport Exhaust
-Mirror Diffusers
-XPel full front/rockers / Ceramic Pro
-Radar Detector ghost install
[] Can you briefly explain why you bought each item you listed? (Example: "Was on Sale", "I considered it the best in the market", etc.)
-Tune & Exhaust - improve torque and power delivery across the range. 100% happy with it. No sluggish revs to redline past 3700 rpm.
-X73 Sport Suspension - improved handling in the twisties + stance. needed something complaint and proven. 100% happy with it.
-XPel full front/rockers / Ceramic Pro - attempt to keep the car protected from hard driving in the canyons and CA highways. 80% happy it, but definitely something I'd do again with a new car purchase.
-Radar - attempt to defray ticket costs, and reduce general idiocy.
I have owned my 2014 CS since April of last year. (Options, SC, PASM, PDK, PSE)
Mods-
Added some deadening material to the back 1/3 of car to reduce drone (PDK/PSE). Somewhat successful but for highway drives I found Bose ear buds to be the best solution.
Bought a used set of stock mufflers but have yet to bother to put them on.
5mm spacers from Suncoast. Wanted to use all Porsche parts
718 strut brace -ditto
x73 sway bars- ditto
I am really happy with the handling improvement especially for the street and the one time I did a DE. PS4 tires also helped.
Softronic Software - bought on sale - feel it is the best hp increase per dollar available for these cars - brings the car slightly beyond base 911 power with a very linear powerband. My feelings all the different softwares change all the same parameters Softronic has been doing this a long time. Their performance claims also made the most sense to me. 360hp is all you can get of these engines regardless of where you start with advertised HP from Porsche.ie 315, 325, or 340. One popular brand claimed approx 7% regardless of starting point of course pay more for a custom tune and you can get close to Softronics claim.
future plans
Center Radiator and maybe a DSC controller.
other than that I just plan to drive it more and enjoy it.
Schnell Autosports 981 Brake Service Special! If you're local and need your brakes serviced, contact us and schedule you next appointment with us!
Our packages include Textar brake pads, Sebro brake pad sensors, installation and full inspection.
*Please email or call us for a quote on replacement brake disc. Let us know if you have any additional questions!
981 Base models
Front brake service package for starting at $384.50
Rear brake service package starting at $286.50
Full brake service package starting at $671.00
981 S models
Front brake service package for starting at $368.50
Full brake service package starting at $655.00
*Prices do not include any applicable taxes.
Schnell Autosports | 1-888-978-9899 Toll Free
9500 7th Street Unit J, Rancho Cucamonga, CA 91730
email: info@schnellautosports.com | schnellautosports.com
81 - 98 of 98 Posts
