Hi Guys,
I posted back in December about my experience going with Numeric Racing shifter cables when my OEM cables broke. You can read that saga here if you like:
http://www.planet-9.com/987-cayman-and-boxster-chat/115977-not-liking-my-numeric-cables.html
The TLDR version is:
I bought a 2008 Cayman S with 76k miles in October. A cable broke in December (OEM, presumably the original cables). I had my preferred shop replace with Numeric Racing cables despite their recommendation to go with the latest OEM cables. I didn't like them for multiple reasons. I insulated them to fix the noise issue, but never got used to the notchy feel.
The update is that when some cold-ish weather finally found it's way to Dallas, the gear selection notchiness seemed worse. Shifting into 1st was really difficult when cold. Going into 2nd and 3rd felt clunky since I could feel multiple points when the gears were synchronizing (seems like I read somewhere these cars have 2-stage synchros on 1st/2nd/3rd gears). Sometimes it felt like it kinda stuck as I was sliding from 2nd to 3rd. 4th/5th/6th felt okay. I finally decided to take the car back in to the shop - not specifically to swap cables but to check if I needed some sort of transmission service.
The owner of this indy shop was a Porsche Master Technician up until about 2013. I had him drive the car cold and he said there was possibly 3 things going on:
1) Most of what I was feeling was due to the way the NR cables transmit absolutely every bit of motion from the transmission selectors.
2) The car has 78k miles now. Gear oil change interval is 90k miles. New oil might improve it.
3) Porsche designed a pin into the tranny that prevents shifting down to 1st at speed. 1st is only meant to be selected from a stop. This pin prevents you from over-revving the engine and bending a valve.
I agreed that the NR cables were not for me. So I agreed to swap to the latest OEM cables. Yes, that's right - after paying $500 for NR cables and $400 for installation, I paid again to swap to OEM. Now there was a lot of discussion in my last thread about which cables are the latest and how much they cost. So I was careful to make sure I got the latest version. I waited as he called Porsche Plano and ordered the cables. They were $376 and they confirmed these are the latest. Yes, I saw Pelican Parts has something for $800. Best I can tell from the diagram is that it also includes a new shifter, boot and handle. Anyway, he charged me the $376 for the cables and only $300 to swap the cables this time. I think he took pity on me since I readily admitted that I should have taken his advice the first time.
The gear oil change was only $50. That seemed like a no-brainer.
Now the 1st gear speed-pin-lockout-thingy (#3) was news to me. The only gear lockouts I've ever experienced were Reverse lockout and the stupid gas saver 1st-to-4th skipshift in my old 1998 Camaro Z28 (LS1 engine). I did a couple of quick Google searches and occasionally see Cayman owners complaining about not being able to select 1st, especially when cold. But nothing yet about this lockout. This guy has proved to be very knowledgeable about all things Porsche so I'm inclined to believe this thing exists. In my case it seems like it certainly is sensitive to cold. Like - once it warms up I can downshift to 1st below 10mph. So I wonder if this "pin" has gotten sticky over time. Who knows, maybe the new gear oil will loosen it up?
So I've driven the car for a whopping 15 miles after getting it back. So far:
The OEM cables feel so much better to me. It's been too long since I drove the car with the original cables, so I can't give you a reasonable comparison there. But compared to the NR cables, the linkage seems so much smoother! I imagine this is what it felt like when new. So very happy. It still definitely limits my entry to 1st gear. At least when cold. I suspect that after warm-up I will find it shifts to 1st okay at low speeds.
Also:
I have some lightly used NR cables and wrench for sale if somebody wants to try them. I'm in the north Dallas TX area. I hope you have a better experience with them than I did.
I can shed some more light about tightening the NR cable coupler nuts - they should be tightened against the end housing (as shown in some of the NR pictures) and not against the coupler (as I had done). The coupler is fused to the reverse-threaded rod that's on the end-housing-side.
Also:
