I think if you work backwards from the PET you can look up the part numbers then the option codes to see what the PCM came from and which options it has.
Jim
Jim
The last two digits are, I believe, similar to a 'version' level. The '11' unit will be newer than the '00' version. Date of manufacture is shown on the small label on the side of the unit. The spec (eg: phone, XM, etc) is shown on the large label on the underside.Thanks! that is awesome. Do you know the difference between part numbers 991.642.963.00 and 991.642.963.11 ? Both are listed for boxster and Cayman. Both have XM and do not have the built in phone
A question for the gurus: a salvage yard I contacted has a unit but they do not know the VIN of the vehicle it came from. Is this a deal killer? Can’t this information be obtained directly from the unit once it’s hooked up to the PIWIS? Do I need the old VIN to get the codes?The last two digits are, I believe, similar to a 'version' level. The '11' unit will be newer than the '00' version. Date of manufacture is shown on the small label on the side of the unit. The spec (eg: phone, XM, etc) is shown on the large label on the underside.
James
I am not sure about if you need the existing VIN to code the PCM but I wouldn't be surprised if you do as i assume the activation code ties the PCM to the VIN to avoid being able to use a stolen unit. As you are searching for a used PCM I would personally be looking for a unit that would have the HW Version 4 which was from a later 2013 or later. This allows you to upgrade the the latest V4.76 software and allows adding some of the lesser expensive back up cameras and also has jukebox and later functions like Email and Text support that the 2012 and early 2013 with HW Version 3 do not have.A question for the gurus: a salvage yard I contacted has a unit but they do not know the VIN of the vehicle it came from. Is this a deal killer? Can’t this information be obtained directly from the unit once it’s hooked up to the PIWIS? Do I need the old VIN to get the codes?
Is there a way to tell what version you have without the unit in hand? Is there something on the label?I am not sure about if you need the existing VIN to code the PCM but I wouldn't be surprised if you do as i assume the activation code ties the PCM to the VIN to avoid being able to use a stolen unit. As you are searching for a used PCM I would personally be looking for a unit that would have the HW Version 4 which was from a later 2013 or later. This allows you to upgrade the the latest V4.76 software and allows adding some of the lesser expensive back up cameras and also has jukebox and later functions like Email and Text support that the 2012 and early 2013 with HW Version 3 do not have.
Jim
You can download the Porsche Parts Catalog (known as PET) from the Suncoast site. It’s about 700 pages and the PCM and antenna wiring diagrams are at the end of the pages. It gives you all of the part numbers. The screenshots I listed above are from the PET. The factory GPS antenna mounts by the rear view mirror but mitch48 mounted his at the base of the windshield with good results.Ok then, I have digested more of this voluminous thread. I am going to need that second mic and a GPS antenna for my 2013 Boxster S 6mt. I am having trouble with the part numbers. The one John Alpin listed for the mic doesn't seem to spec for the 2013 boxster. I have to say that I am really not good at finding these parts on the internet. None of the usual parts sites seem to list them.
Question: Do I need the Porsche GPS antenna or will an aftermarket job work just as well. This goes behind the rearview mirror, correct? Thaks!
No, you do not need the VIN of the donor vehicle. The codes you will need to buy and have loaded (coded) to your vehicle will be issues against your car's VIN. You will need to provide the VIN of your car when you purchase the codes.A question for the gurus: a salvage yard I contacted has a unit but they do not know the VIN of the vehicle it came from. Is this a deal killer? Can’t this information be obtained directly from the unit once it’s hooked up to the PIWIS? Do I need the old VIN to get the codes?
Your PCM (model 9633) looks good to go! As you say, the later model with Jukebox capability etc.Ok then, I have digested more of this voluminous thread. I am going to need that second mic and a GPS antenna for my 2013 Boxster S 6mt. I am having trouble with the part numbers. The one John Alpin listed for the mic doesn't seem to spec for the 2013 boxster. I have to say that I am really not good at finding these parts on the internet. None of the usual parts sites seem to list them.
You can do what I did and get a generic GPS antenna and mount at the base of the windshield, works as well imo.Ok then, I have digested more of this voluminous thread. I am going to need that second mic and a GPS antenna for my 2013 Boxster S 6mt. I am having trouble with the part numbers. The one John Alpin listed for the mic doesn't seem to spec for the 2013 boxster. I have to say that I am really not good at finding these parts on the internet. None of the usual parts sites seem to list them.
Get a T-design magnetic phone holder and use phone for gps...free updates.Now just waiting for my car to be delivered. The PCM I got off ebay will be here Saturday. I'm thinking that a generic GPS will work just as well as the Porsche one, which along with connecting cable costs $160. Thanks mitch48.
As Mitch has said, I think you'll fine that Porsche will not sell you the codes directly but the source that several of us have used, based in Russia, is very reliable and fast. You will need your Porsche dealer (or a good independent that has a PIWIS kit that can access the Porsche central vehicle database) to load and activate the codes for your car, though.I’m about to undertake this adventure as well. Found a head unit on eBay $899. Seller only has the cars Vin number. No codes.
So I’ll have to buy the codes from Porsche. Anyone know the cost?
And just to confirm. I’ll need:
GPS antenna
2x microphones
Mic harness 991 044 900 37
USB Cable
Glove box cap for usb.
I have a 2015 Cayman S. With Bose. CDR31. No navigation.
