Hi Gang,
I have a Cayman base (981) with the oval exhaust tip, I bought a sport exhaust tip from a planet9 member. My question is how easy is to swap them? I have read that you need to remove one of the wheels. Others said that you don't need to remove the wheel.
Another thing, using jack stands or ramps should be ok to lift the car to access the nuts to remove the tip.
Also, Is this a one person job or I need someone else to help me?
Finally, if you have experience doing this job, was the job a DYI or a shop job?
Thank you for your help!
