1 - 9 of 9 Posts
I took my car to the Porsche dealer to have a flat tire repaired. Turns out the nail was in the sidewall of the tire so had to buy a new tire. Car has 8,000 miles. All original tires. Replaced the left rear with a new Dunlop which is the same tire that came on the car new. A friend yesterday told me that the new tire might cause a problem with traction control even though car only has 8,000 miles. Any comments? Thanks
Thanks Budman. I didn't think there would be a problem. Surely a top notch Porsche dealer wouldn't mount that tire if there was any chance of causing a handling problem or damage to traction control. Thanks again for your reply.
You might want to check tread depths. If the difference between the new and old tire is more than a few 32nds, you certainly could have issues with traction control. One option is to shave the new tire to the diameter of the worn one.
I called the Porsche dealer and spoke with the service manager. He tells me that Porsche says if there is 30% or more difference in tread depth they will replace both rear tires. They measured and I didn't have 30% difference. Also, he tells me that if there is a problem the light will come on and stay on. No light. I will also go buy a gauge and take a look myself. Thanks again
I'd be rare to have less than 30% thread wear on a summer tire with 8K miles, even if you drive like a grandma, so yes, check them yourself;). An additional problem is the new tire will be grippier, since rubber degrades with age, plus the heating cycles, so I'd always replace both. Good luck.
Oh, and the correct way to determine that 30% is USEFUL tread depth, not total tread depth, since you're not supposed to use the tires past their wear indicator, which typically is 4/32;). Something else to ponder.
Discussion Starter · #9 ·
Thanks ELP_JC I don't race or track the car so tires look new. I guess I have worn the tire less than 30% according to my Porsche dealer. Talked to them today and they assure me I am OK. Thanks for everybody responses.
1 - 9 of 9 Posts
